Pictures not showing in printed versions of reports (or in print previews)
2015-09-28T16:28:54+00:00
Hi all,
I have an access acce that i run on two different machines, one of which is in windows 10 /Office 2016, the other one is in Windows 10 / Office 2010. My Acces prints out perfectly on the 2010 version of Access and no image is coming our on the 2016 version on Office (the same Accde was printing perfectly as i had Access 2013 before the weekend) now no image is coming out on the print.
If I look on screen at the report, pictures are there, as soon as I get onto the print preview, images are gone !
This is probably a new feature of access 2016 that I am not aware of !
Can anybody help me ?
Thanks in advance
Marc
Microsoft 365 and Office | Access | For home | Windows
ScottGem 68,840 Reputation points Volunteer Moderator
2015-11-09T18:23:13+00:00
Patrick, I fully understand the affect this has had. And I couldn't agree more that a way of going back should have been made available. But it doesn't really matter how specific the issue is, a fix needed to be found, tested and then implemented within the rollout cycle. As I understand it a potential fix was identified late in October. And the testing made it miss the November cycle. Hence the December release.
153 additional answers
    2015-09-30T15:28:25+00:00
    acOLESizeZoom is either missing or, more likely, broken. acOLESizeClip and acOLESizeStretch work, but if you try to set the SizeMode property to Zoom the image does not display at all.
    No other image property seems to affect whether the image displays or not, just SizeMode.
    I don't know what your connections to Microsoft are, but you seem to be the only one in this thread that could get in contact with someone to fix this issue. Microsoft seems to be ignoring it all together or doesn't bother looking at user issues.
  2. Tom van Stiphout 40,216 Reputation points MVP Volunteer Moderator
    2015-10-01T02:56:24+00:00
    As I wrote in another thread: the Access team is aware of this and actively working on a solution.
    In the meantime I am happy users are investigating on their own and finding workarounds.
    2015-10-01T16:36:37+00:00
    Tom,
    It has nothing to do with age of file. I created a entirely new file and have the same results.
    I have changed the pics from jpg to bmp and the results remain the same.
    I can see the pictures in report view and layout view, but not in Print Preview nor when printed.
    RichardGVAZ
    2015-10-01T19:50:13+00:00
    I have tried all combinations of image control also.
    I find that it is all about the Size Mode settings. Clip and Stretch both work but greatly distort the pictures as you might expect.
    In my version the Picture Type makes no difference. Shared, Embedded and Linked all work the same.
    I am running windows 10 with access 2016.
    I have a windows tablet that is running windows 8.1 with access 2013 and it works perfectly. I hope office 365 never forces me to upgrade that to office 2016 or my reports are all lost.
    RichardGVAZ
