Pictures not showing in printed versions of reports (or in print previews)
2015-09-28T16:28:54+00:00
Hi all,
I have an access acce that i run on two different machines, one of which is in windows 10 /Office 2016, the other one is in Windows 10 / Office 2010. My Acces prints out perfectly on the 2010 version of Access and no image is coming our on the 2016 version on Office (the same Accde was printing perfectly as i had Access 2013 before the weekend) now no image is coming out on the print.
If I look on screen at the report, pictures are there, as soon as I get onto the print preview, images are gone !
This is probably a new feature of access 2016 that I am not aware of !
Can anybody help me ?
Thanks in advance
Marc
Microsoft 365 and Office | Access | For home | Windows
ScottGem 68,840 Reputation points Volunteer Moderator
2015-11-09T18:23:13+00:00
Patrick, I fully understand the affect this has had. And I couldn't agree more that a way of going back should have been made available. But it doesn't really matter how specific the issue is, a fix needed to be found, tested and then implemented within the rollout cycle. As I understand it a potential fix was identified late in October. And the testing made it miss the November cycle. Hence the December release.
153 additional answers
  1. ScottGem 68,840 Reputation points Volunteer Moderator
    2015-12-08T21:32:55+00:00
    Did you check to make sure the hotfix was installed. As I understand it the fix was only released a little over an hour ago.
    2015-12-08T21:51:55+00:00
    I just went in an applied all of the updates (via file > account > update options > update now), have rebooted machine and still my images don't appear.  I've delayed fixing myself due to the man hours required, but am now wondering if I have no other option.  Very disappointed Microsoft.
    2015-12-08T21:53:06+00:00
    Actually, no I'm not convinced now. It did do an update for Office though, but I can't really determine if the hotfix has been included.
    Hopefully it is still to hit the server and another Office Update is still to pick it up.
  4. ScottGem 68,840 Reputation points Volunteer Moderator
    2015-12-08T21:55:08+00:00
    But did you check to make sure the specific number fixes were applied? Even though MS has released the patches it doesn't mean they are available on every server. You need to verify That the patches installed match the patches on that link I posted.
