Pictures not showing in printed versions of reports (or in print previews)
2015-09-28T16:28:54+00:00
Hi all,
I have an access acce that i run on two different machines, one of which is in windows 10 /Office 2016, the other one is in Windows 10 / Office 2010. My Acces prints out perfectly on the 2010 version of Access and no image is coming our on the 2016 version on Office (the same Accde was printing perfectly as i had Access 2013 before the weekend) now no image is coming out on the print.
If I look on screen at the report, pictures are there, as soon as I get onto the print preview, images are gone !
This is probably a new feature of access 2016 that I am not aware of !
Can anybody help me ?
Thanks in advance
Marc
Microsoft 365 and Office | Access | For home | Windows
ScottGem 68,840 Reputation points Volunteer Moderator
2015-11-09T18:23:13+00:00
Patrick, I fully understand the affect this has had. And I couldn't agree more that a way of going back should have been made available. But it doesn't really matter how specific the issue is, a fix needed to be found, tested and then implemented within the rollout cycle. As I understand it a potential fix was identified late in October. And the testing made it miss the November cycle. Hence the December release.
153 additional answers
    2015-11-14T18:53:00+00:00
    This is a HUGE problem for us too.  I run a software company that uses Access and the front end application for SharePoint linked tables.  It has been working great for several years, but now our clients that are upgrading to Office 2016 cannot see the photos that should be embedded and displayed the the PDFs that the app creates from reports.
    Microsoft Access Team: please fix this!
    2015-11-21T17:36:44+00:00
    Than you for your post, this work around took care of my problem!
    2015-11-23T19:35:02+00:00
    Hi, how will I know when the December update is out?
    2015-11-30T23:44:50+00:00
    Well From the little testing I have just done to try and fix this bug on my app, I can tell you Access 2016 is NOT as stable as Access 2013!
    Work around to set options-current db-convert seems to work but I had to play around with clip/zoom/stretch multiple times before it seems to take effect.
    Reports now previewing  with linked images set to jpg and outputting to pdf ok
