Pictures not showing in printed versions of reports (or in print previews)
2015-09-28T16:28:54+00:00
Hi all,
I have an access acce that i run on two different machines, one of which is in windows 10 /Office 2016, the other one is in Windows 10 / Office 2010. My Acces prints out perfectly on the 2010 version of Access and no image is coming our on the 2016 version on Office (the same Accde was printing perfectly as i had Access 2013 before the weekend) now no image is coming out on the print.
If I look on screen at the report, pictures are there, as soon as I get onto the print preview, images are gone !
This is probably a new feature of access 2016 that I am not aware of !
Can anybody help me ?
Thanks in advance
Marc
Microsoft 365 and Office | Access | For home | Windows
ScottGem 68,840 Reputation points Volunteer Moderator
2015-11-09T18:23:13+00:00
Patrick, I fully understand the affect this has had. And I couldn't agree more that a way of going back should have been made available. But it doesn't really matter how specific the issue is, a fix needed to be found, tested and then implemented within the rollout cycle. As I understand it a potential fix was identified late in October. And the testing made it miss the November cycle. Hence the December release.
153 additional answers
    2015-09-30T04:31:13+00:00
    As far as I can tell ,on my end anyway, it's only when I have the picture Size Mode property is set to Zoom. Setting to Stretch or Clip allow the photo to be printed.
    Hopefully this gets resolved soon. I don't want to have to redo all of my reports. I have hundreds of pictures that would have to be changed.
    2015-09-30T04:44:20+00:00
    I'm seeing this too. I have an image control whose Size Mode is set to Zoom, and none of the images associated with that control are displaying now that I upgraded to Access 2016 today. I'm happy to supply any other information that might help lead to a quick resolution of this issue.
    Jay Karamales
    Olórin Press
    Boise, ID
    2015-09-30T09:58:40+00:00
    The problem appears to me to be when you print a picture or file to onenote 2016 desktop the image can be viewed on the  onenote 2016, but when it syncs to the online onenote server the images or files are blank with just an x[image] displayed. So when your mobile devices sync to the online server they also show blank pages.
    If you insert the same photo or file on onenote 2016 then it all works ok and can be viewed on onenote online and of course on synced mobile devices.
    The problem is when you print images and files to onenote 2016.
    Kevin
    2015-09-30T13:37:41+00:00
    I have the same issue. No images, including my logos, are printing. It's the same in print preview, no images showing up. I tried several printers including Adobe PDF, checked and tried different printer settings. Reinstalled office, Reinstalled print driver with latest update for windows 10 64b. I went through all the access file options. I found nothing. I does work the change the size mode on the image property sheet to clipped. However, I have many DB's with hundreds of reports. This will be a horrible to change them all. Also, not sure if clipped will change the image appearance. I tried tech support, and unless I want to pay $500 they wont help.
