Pictures not showing in printed versions of reports (or in print previews)
2015-09-28T16:28:54+00:00
Hi all,
I have an access acce that i run on two different machines, one of which is in windows 10 /Office 2016, the other one is in Windows 10 / Office 2010. My Acces prints out perfectly on the 2010 version of Access and no image is coming our on the 2016 version on Office (the same Accde was printing perfectly as i had Access 2013 before the weekend) now no image is coming out on the print.
If I look on screen at the report, pictures are there, as soon as I get onto the print preview, images are gone !
This is probably a new feature of access 2016 that I am not aware of !
Can anybody help me ?
Thanks in advance
Marc
Microsoft 365 and Office | Access | For home | Windows
ScottGem 68,840 Reputation points Volunteer Moderator
2015-11-09T18:23:13+00:00
Patrick, I fully understand the affect this has had. And I couldn't agree more that a way of going back should have been made available. But it doesn't really matter how specific the issue is, a fix needed to be found, tested and then implemented within the rollout cycle. As I understand it a potential fix was identified late in October. And the testing made it miss the November cycle. Hence the December release.
153 additional answers
    2015-10-16T23:38:31+00:00
    If they can't fix it right away they should send out some sort of alert or notice so we don't waste time trying to fix their problem - unless that is their intent.....
    I just spent a half hour or more trying to get it to work before I found this forum and discovered it's actually an old problem that has yet to be fixed
    Microsoft - Save Us Time - Admit and Alert Us when your shiny new stuff doesn't work ......
    Then get it fixed :)
    2015-10-20T16:02:12+00:00
    I am also having this issue. Is there any update from Microsoft on a time table for a fix?
  3. ScottGem 68,840 Reputation points Volunteer Moderator
    2015-10-20T16:34:26+00:00
    The last we have been told was a fix was being tested and should appear with the December updates.
    2015-10-20T18:01:43+00:00
    I just installed 2016 and ran into this issue.  Reading through this discussion and now seeing the issue won't be fixed until at least the December updates is quite disturbing.  I'm a long time IT person and 4 months to fix an issue in a production system would land me into a lot of trouble.  Hopefully I can find an older version somewhere as I need to publish this report long before December.
