MS Project 2016
2015-09-29T13:32:35+00:00
When I click on Assign Resources MS Project shuts down ?  Has this happened to others and is there a solution, or suggestions for a good around ?
Microsoft 365 and Office | Access | For home | Windows
Dale Howard [MVP] 29,880 Reputation points MVP
2015-12-29T19:47:02+00:00
All --
I reported this problem to my contacts at Microsoft, and they found out what you are experiencing is a bug due to the "presence" indicator that comes through Outlook and Skype for Business.  The bug is now slated for fixing, but there is no timeline on when the bug fix will be released.  In the meantime, please try the following in Microsoft Project 2016 to disable the "presence" indicator for resources:
  1. Click File > Options > Display.
  2. DESELECT the "Online status next to name" checkbox.
  3. Click the OK button.
Does this help?  Please let us know.
49 additional answers
  1. Dale Howard [MVP] 29,880 Reputation points MVP
    2015-12-29T23:09:30+00:00
    Bill --
    If my post solved your problem, would you kindly mark it as the answer to this question?  Thanks!
    2015-12-30T01:05:04+00:00
    My Program still closes. ???  Thanks for responding, at least someone is looking into it.
    2016-01-05T09:10:08+00:00
    I have did what you say but Project 2016 still crash.
    2016-01-05T19:05:52+00:00
    Um, no, didn't help my situation.  Whenever I go to File>Open Project 2016 shutsdown.
