Excel 2016 for Mac does not recalculate
2015-08-01T00:09:35+00:00
I have a multiple-sheet workbook that does not recalculate after I update some cells. It would only recalculate after I save and then reopen it. My Excel preferences is set to automatic recalculate. After I change the value of cells, the workbook does not recalculate even after I press the F9 key. I have tried Command+F9 to no avail. The workbook had a data connection and I had deleted it. The version is 15.12.3. Any idea what I can do?
Microsoft 365 and Office | Excel | For home | MacOS
2017-07-09T08:51:04+00:00
ref my earlier question I found an answer that worked:
Why does my formula not calculate in Excel?
Instead the text of the formula itself appears in the cell directly. See example below. Cause: The cell is formatted as Text, which causes Excel to ignore any formulas. This could be directly due to the Text format, or is particularly common when importing data from a CSV or Notepad file
I copied the data from the original import worksheet into a fresh worksheet and the formulas worked fine
2016-09-15T18:53:52+00:00
As Anthony noted, version 15.26 (160903) does contain the fix. This version has now been released to all audiences. Please make sure your Office is up to date and this problem should be resolved.
Thank you all for your patience and persistence!
Freya
Office Newsroom
112 additional answers
    2015-12-04T17:34:17+00:00
    I reported it several times via the smiley face also. My solution galls me but I bought a Surface Pro 3 to replace my apple laptop. I often wonder if this is a strategy for MS, Put a less then optimal product out for Apple, then hope users get **** off enough to buy MS Windows based products?
  2. Jim G 134K Reputation points MVP
    2015-12-06T16:09:38+00:00
    Possibly, but I think you are giving Microsoft more credit than they deserve. I don't know of any successful marketing strategies that involve delivering crappy products.
  3. Jim G 134K Reputation points MVP
    2015-12-06T16:19:52+00:00
    You can purchase support from Microsoft or use one of the other support options on this page. When you use purchased support incidents, you will receive a ticket number and  response directly from Microsoft.
