Excel 2016 for Mac does not recalculate
2015-08-01T00:09:35+00:00
I have a multiple-sheet workbook that does not recalculate after I update some cells. It would only recalculate after I save and then reopen it. My Excel preferences is set to automatic recalculate. After I change the value of cells, the workbook does not recalculate even after I press the F9 key. I have tried Command+F9 to no avail. The workbook had a data connection and I had deleted it. The version is 15.12.3. Any idea what I can do?
Microsoft 365 and Office | Excel | For home | MacOS
2017-07-09T08:51:04+00:00
ref my earlier question I found an answer that worked:
Why does my formula not calculate in Excel?
Instead the text of the formula itself appears in the cell directly. See example below. Cause: The cell is formatted as Text, which causes Excel to ignore any formulas. This could be directly due to the Text format, or is particularly common when importing data from a CSV or Notepad file
I copied the data from the original import worksheet into a fresh worksheet and the formulas worked fine
2016-09-15T18:53:52+00:00
As Anthony noted, version 15.26 (160903) does contain the fix. This version has now been released to all audiences. Please make sure your Office is up to date and this problem should be resolved.
Thank you all for your patience and persistence!
Freya
Office Newsroom
112 additional answers
  1. Jim G 134K Reputation points MVP
    2016-12-12T16:05:49+00:00
    Your installation is way out of date.
    Make sure your Mac has a working internet connection before checking for updates. Install Mac OS X updates followed by Office updates.
    Mac OS X updates:
    To get Mac OS updates, go to the App store on your dock, and then click the Updates button to reveal available updates.
    Office Updates
    To get the update:
    1. Open any Office application:
    2. Make sure your Mac has a working internet connection
    3. Go to the Help menu and choose Check for Updates
    4. Let AutoUpdate check for and install updates
    5. Restart your Mac
    2016-12-12T17:29:38+00:00
    to Jim Gordon:
    My original question / comment: “I have Excel for Mac version 15.26 and have the problem of numerical cell input occasionally not showing up until I page up or down.  Why doesn’t it immediately show up on the spreadsheet?  This was not a problem for me with the 2011 version.”
    Your response: “Your installation is way out of date … make sure your Mac has a working internet connection”
    I am using mac OS Sierra 10.12.1 and was using Excel for Mac v. 15.26, which was acquired in Sept. 2016 from Microsoft – so this is “way out of date”?  Really – can’t Microsoft distribute a new version of Excel that consistently and immediately shows numerical input into cells, as the product has since I first starting using Excel in the 1980s??
    Richard Tatman
    2016-12-13T11:18:33+00:00
    I can (unfortunately) confirm that this is still an issue. I am running Excel 15.27, Danish version (which is the newest - there are no updates available in MAU), and on macOS Sierra 12.1
    Cheers,
    Peter
