Excel 2016 for Mac does not recalculate
2015-08-01T00:09:35+00:00
I have a multiple-sheet workbook that does not recalculate after I update some cells. It would only recalculate after I save and then reopen it. My Excel preferences is set to automatic recalculate. After I change the value of cells, the workbook does not recalculate even after I press the F9 key. I have tried Command+F9 to no avail. The workbook had a data connection and I had deleted it. The version is 15.12.3. Any idea what I can do?
Microsoft 365 and Office | Excel | For home | MacOS
2017-07-09T08:51:04+00:00
ref my earlier question I found an answer that worked:
Why does my formula not calculate in Excel?
Instead the text of the formula itself appears in the cell directly. See example below. Cause: The cell is formatted as Text, which causes Excel to ignore any formulas. This could be directly due to the Text format, or is particularly common when importing data from a CSV or Notepad file
I copied the data from the original import worksheet into a fresh worksheet and the formulas worked fine
2016-09-15T18:53:52+00:00
As Anthony noted, version 15.26 (160903) does contain the fix. This version has now been released to all audiences. Please make sure your Office is up to date and this problem should be resolved.
Thank you all for your patience and persistence!
Freya
Office Newsroom
112 additional answers
    2016-07-19T11:09:02+00:00
    "At least we now know that performing extra (and annoying) refresh key strokes such as cmd-R and/or scrolling the screen onto and off the offending cells will deliver the required result."
    NO, not in my case. As I said the only way to recalculate anything is to go into each single cell and hit the return button. No cmd-R or other combination will do that and the entire spreadsheet will not recalculate.
  2. Jim G 134K Reputation points MVP
    2016-07-19T17:05:07+00:00
    Are you a Fast Track member?  If so, can you bring this issue up on the forum on all our behalves?
    Hi Anthony,
    Yes I am a fast track member, but no I can't report it for you because I don't have two monitors and can not reproduce the problem.
    You can (and should) report the problem using the Smile button in Excel after each Microsoft Office update that you install and after each Mac OS update that you install and let Microsoft know whether or not the problem you are experiencing has been corrected. In all likelihood you won't get a personal reply, but those submissions go directly to the Excel product team.
    From the recent comments in this thread it seems there is more than one scenario causing a similar problem for users. Hardware is certainly a factor (two monitors is a minimum hardware configuration to have the problem at all). Whether it is a video driver issue, refresh issue, an Excel issue, a Mac OS issue or some specific combination of these factors I don't know. I can't do much to solve this mystery as I can't even reproduce it.
    2016-07-19T23:27:54+00:00
    have one monitor a late 2011 MacBook pro - I have this problem, and have had since Office 2016 came out
