Excel 2016 for Mac does not recalculate
2015-08-01T00:09:35+00:00
I have a multiple-sheet workbook that does not recalculate after I update some cells. It would only recalculate after I save and then reopen it. My Excel preferences is set to automatic recalculate. After I change the value of cells, the workbook does not recalculate even after I press the F9 key. I have tried Command+F9 to no avail. The workbook had a data connection and I had deleted it. The version is 15.12.3. Any idea what I can do?
Microsoft 365 and Office | Excel | For home | MacOS
2017-07-09T08:51:04+00:00
ref my earlier question I found an answer that worked:
Why does my formula not calculate in Excel?
Instead the text of the formula itself appears in the cell directly. See example below. Cause: The cell is formatted as Text, which causes Excel to ignore any formulas. This could be directly due to the Text format, or is particularly common when importing data from a CSV or Notepad file
I copied the data from the original import worksheet into a fresh worksheet and the formulas worked fine
2016-09-15T18:53:52+00:00
As Anthony noted, version 15.26 (160903) does contain the fix. This version has now been released to all audiences. Please make sure your Office is up to date and this problem should be resolved.
Thank you all for your patience and persistence!
Freya
Office Newsroom
112 additional answers
    2016-07-18T08:21:29+00:00
    Well, it's been a while since i've even bothered trying and having missed roughly 6 months worth of updates, i finally tried again today with the 15.24 update.
    Still no different, in fact i think it might be worse if that's possible.  Even just a single reference to an off screen field isn't changing when the reference field is amended.
    I'll keep waiting for the 64-bit fix (?), and using Excel 2011 in the meantime.  I still have trouble believing that i am paying a subscription fee for a spreadsheet software package that can't perform the most basic spreadsheet function reliably.
    2016-07-18T08:57:14+00:00
    Hi Mikko,
    could you please do me the favor and explain again when the bug occurs: "JUST A SINGLE REFERENCE TO AN OFF SCREEN FIELD ISN'T CHANGING WHEN THE REFENCE FIELD IS AMANEDED".
    What do you mean by "off screen field"?
    What do you mean by "amanding the reference field"?
    Thank you,
    Stepha
    2016-07-18T09:16:05+00:00
    If I reference field A1 for example by typing "=A1" in field D37 for example and then scroll so I can't see D37.
    If I amend A1 to whatever else, in this case I just had text in that field, then scroll back down to see D37, it hasn't changed even though the field it refers to has.
