Excel 2016 for Mac does not recalculate
2015-08-01T00:09:35+00:00
I have a multiple-sheet workbook that does not recalculate after I update some cells. It would only recalculate after I save and then reopen it. My Excel preferences is set to automatic recalculate. After I change the value of cells, the workbook does not recalculate even after I press the F9 key. I have tried Command+F9 to no avail. The workbook had a data connection and I had deleted it. The version is 15.12.3. Any idea what I can do?
Microsoft 365 and Office | Excel | For home | MacOS
2017-07-09T08:51:04+00:00
ref my earlier question I found an answer that worked:
Why does my formula not calculate in Excel?
Instead the text of the formula itself appears in the cell directly. See example below. Cause: The cell is formatted as Text, which causes Excel to ignore any formulas. This could be directly due to the Text format, or is particularly common when importing data from a CSV or Notepad file
I copied the data from the original import worksheet into a fresh worksheet and the formulas worked fine
2016-09-15T18:53:52+00:00
As Anthony noted, version 15.26 (160903) does contain the fix. This version has now been released to all audiences. Please make sure your Office is up to date and this problem should be resolved.
Thank you all for your patience and persistence!
Freya
Office Newsroom
112 additional answers
    2016-07-04T22:00:00+00:00
    You might get the impression from the press that Microsoft and Apple are at odds about everything, but they actually work together closely to ensure Office for Mac works correctly.
    Updating Mac OS when you update office apps is a good way to ensure you have the least amount of trouble.
    I have latest Mac OD installed and Office 365 V.15.23.2 (latest version as at 4 July 2016. This is many updates since the problem was first reported). I reinstalled Office 365 having deleted all the MS elements in Library etc. Obvious stuff like Preference setting to auto calculate done. Spent hours copying/deleting and even rebuilding spreadsheets. But, no improvement. Some formulas recalculated, most didn't except after using cmd_R. This is too risky for business use and so will be using Apple Numbers in future. Having read previous forum reports is is clear that Microsoft don't seem to be interested in fixing a very fundamental issue.
    2016-07-05T13:36:58+00:00
    Not sure if this workaround has been posted, but the problem does not occur when working in Page Layout view.
  3. Jim G 134K Reputation points MVP
    2016-07-05T14:26:05+00:00
    Switching to Normal view has fixed the problem for others, as well. Please give it a try.
    Be sure to let Microsoft know about the problem in the current update by using the Smile button in Excel.
