Word 2016 hangs when opening a document based on a template
2015-10-04T11:47:18+00:00
I store my documents in:
OneDrive\Shared Documents\Business
and my templates in
OneDrive\Shared Documents\Templates
As I've done for over a year.
All worked fine in Office / Word 2013
Word 2016 will hang if I try and open a document that is based on a template.
The templates are available.
I've tried renaming the templates and removing spaces in the names but that didn't help.
If I remove the template the document will open and show as based on Normal.dotx.
All templates and documents use the new 2016 file format and are saved as .dotx.
Please note:
I'd rather you didn't reply to this issue if you haven't actually experienced this problem or if you haven't actually tried the fix you propose.
  1. Stefan Blom 352.3K Reputation points MVP Volunteer Moderator
    2016-10-31T21:12:12+00:00
    The Templates and Add-Ins dialog box lets you do the following:
    • Load a template into memory so that its building blocks, key assignments and macros are available to all documents. Such a template is often referred to as a Startup add-in (or global template).
    • Change which template is attached to the current document.
    There is an important distinction between these two actions. Normally, you want specific templates to be loaded as add-ins (and you do that by putting these templates in Word's Startup folder). Most templates should be attached to specific documents.
    Documents that do not need a specific template should have the Normal template attached to them.
    2017-05-02T13:54:49+00:00
    In your OneDrive Application => settings => untick
    • Use Office to Sync Files
    • Use Office 2016 to sync files that I open
    2017-09-18T03:55:25+00:00
    Thank you, Yves!
    This allows me to work-around the issue.
    I had to go to File -> Options -> Customize Ribbon, then select 'Developer' on the right hand side to show the Developer tab first before I could use your advice, but that's worked great now that I've done that.
    Such a frustrating issue, though and still outstanding in Windows 10 build 1511 10586.1106 and Office 2016 MSO version 16.0.4549.1000 32-bit.
