Word 2016 hangs when opening a document based on a template
2015-10-04T11:47:18+00:00
I store my documents in:
OneDrive\Shared Documents\Business
and my templates in
OneDrive\Shared Documents\Templates
As I've done for over a year.
All worked fine in Office / Word 2013
Word 2016 will hang if I try and open a document that is based on a template.
The templates are available.
I've tried renaming the templates and removing spaces in the names but that didn't help.
If I remove the template the document will open and show as based on Normal.dotx.
All templates and documents use the new 2016 file format and are saved as .dotx.
Please note:
I'd rather you didn't reply to this issue if you haven't actually experienced this problem or if you haven't actually tried the fix you propose.
  1. Stefan Blom 352.3K Reputation points MVP Volunteer Moderator
    2016-07-12T12:24:15+00:00
    There was an update released a few months back, but it seems that it didn't work for everybody. I'll ask the Office team for a follow-up.
    In the meantime, have you tried manually changing the attached template to Normal.dotm?
    2016-07-12T12:30:26+00:00
    Yes, it works. The hard part is getting to open the document so as to change it :)
    So what you have to do is:
    1. Open the Template, that the document uses, and keep it open.
    2. Open the Word document, that uses the template
    3. Open Templates and Add-ins windows and change the template to normal.dotm
    4. Save
    Then it works.
    But as said previously: It's a (rather bad) workaround, not a fix. We need a hotfix :)
    Thank you for taking this to the Office Team!
    2016-07-12T12:47:42+00:00
    Just wanted to point out that a workaround is to store the templates in a non-shared OneDrive folder. This enables the documents to open without problems
    2016-07-12T12:56:14+00:00
    So, if I store the Templates on OneDrive, but in a folder, that has not been shared, it shouldn't be an issue?
    I don't remember sharing this folder (with the template in), but I will check.
    And still, this doesn't help with all the Word documents, that have been created pointing to the previous problem-location, I guess...
    2016-07-12T12:57:41+00:00
    Update: My .dotx file is stored on OneDrive in a folder, that is not shared... And I have this problem.
