I store my documents in:
OneDrive\Shared Documents\Business
and my templates in
OneDrive\Shared Documents\Templates
As I've done for over a year.
All worked fine in Office / Word 2013
Word 2016 will hang if I try and open a document that is based on a template.
The templates are available.
I've tried renaming the templates and removing spaces in the names but that didn't help.
If I remove the template the document will open and show as based on Normal.dotx.
All templates and documents use the new 2016 file format and are saved as .dotx.
Please note:
I'd rather you didn't reply to this issue if you haven't actually experienced this problem or if you haven't actually tried the fix you propose.
