Word 2016 Paragraph Indent Problems
2015-12-27T18:52:48+00:00
I've been experiencing a problem in Word documents since the upgrade to '16 a few weeks ago. My paragraphs keep randomly un-indenting, or indenting double. I'll fix all the problems, save the document and next time I open it, there's random indent again. Sometimes it's the same place, sometimes it is in a different location. Sometimes it even happens while I'm working in an open document! I've tried taking out all the formatting and starting over, I've tried resetting the paragraph parameters...nothing seems to help.
Any ideas on a fix? This problem is not only distracting, but also very frustrating because I'm not getting any real work done! It's driving me nuts!
Thanks for any help or suggestions. Appreciate it!
Beth
UPDATE 1/14: I received a reply from Doug after I sent my diagnostic file to be reviewed by a Microsoft team:
I have received information from the Word Product Team that they have identified the cause of the issue and are presently validating a fix for it.
In the meantime, it appears that toggling the display of “non-printing” characters by the use of the Show\Hide (¶) button on the home tab of the ribbon, causes the screen to be re-painted which will cause the indents to re-appear.  However, the issue *will* return again following subsequent edits, so it will be necessary to toggle the show\hide every now and then.
Apparently, it is a display only issue and printing should produce the document laid out correctly with the indents in place.
So at least we know now what the issue is, hopefully a fix will not take that long. I see down the thread that Justin has reverted to '13 with no major issues, so that could be a good solution for those of you in need of proper paragraphs yesterday. Thanks to everyone for their help and suggestions and best of luck!
Beth
2016-01-27T20:26:16+00:00
Hi everyone. We just released a new update that should resolve the following formatting/selection issues:
  • Sections that should be indented, are not indented
  • Tabs no longer display correctly
  • Strange pieces of characters are left on the screen
  • Selection range is incorrect, (Word doesn't select the text you choose)
  • Bullet and Number Lists don't display correctly
For more information, see: FIXED 1/26/16: Word 2016 doesn't display your document formatting correctly when you edit a document in progress.
Please try it out and let us know if you run into any trouble.
Thank you.
2016-01-23T19:11:44+00:00
Yes, these all sound like part and parcel of the same bug. The symptoms are:
  • Strange pieces of characters are left on the screen (i.e., the screen painting issue)
The good news is that the fix for the bug has already gone out to our Office Insider audience, which means that it should roll out to the rest of you soon. Here's a bit more info about how the Office 365 updates work: How do I get the newest features in Office 2016 for Office 365?
I also want to take a moment to say that we appreciate each of you reporting your issues and working with us to resolve these bugs. We are listening closely.
57 additional answers
    2016-01-23T18:19:59+00:00
    This is a painting issue we've been discussing in another thread. IMHO, it's related. (Related painting issue)
    And no, this isn't fixed either--but I'm told they're working on it.
    2016-01-23T18:39:50+00:00
    Now, in addition to the indents being messed up, the tops and/or bottoms of lines of text are occasionally getting wonky. I have a hard time believing this could be my graphics card or my monitor; my laptop's only a year old, and this problem only happens in Word.
    I'm having the same display issue. It clears up with I toggle the show/hide button, just as the indentation problem does. Until it shows up again.
    I wish we could hear from Microsoft when they think they will have a fix.
    2016-01-23T21:10:56+00:00
    Really?  Your version doesn't have this tab?
