Word 2016 Paragraph Indent Problems
2015-12-27T18:52:48+00:00
I've been experiencing a problem in Word documents since the upgrade to '16 a few weeks ago. My paragraphs keep randomly un-indenting, or indenting double. I'll fix all the problems, save the document and next time I open it, there's random indent again. Sometimes it's the same place, sometimes it is in a different location. Sometimes it even happens while I'm working in an open document! I've tried taking out all the formatting and starting over, I've tried resetting the paragraph parameters...nothing seems to help.
Any ideas on a fix? This problem is not only distracting, but also very frustrating because I'm not getting any real work done! It's driving me nuts!
Thanks for any help or suggestions. Appreciate it!
Beth
UPDATE 1/14: I received a reply from Doug after I sent my diagnostic file to be reviewed by a Microsoft team:
I have received information from the Word Product Team that they have identified the cause of the issue and are presently validating a fix for it.
In the meantime, it appears that toggling the display of “non-printing” characters by the use of the Show\Hide (¶) button on the home tab of the ribbon, causes the screen to be re-painted which will cause the indents to re-appear.  However, the issue *will* return again following subsequent edits, so it will be necessary to toggle the show\hide every now and then.
Apparently, it is a display only issue and printing should produce the document laid out correctly with the indents in place.
So at least we know now what the issue is, hopefully a fix will not take that long. I see down the thread that Justin has reverted to '13 with no major issues, so that could be a good solution for those of you in need of proper paragraphs yesterday. Thanks to everyone for their help and suggestions and best of luck!
Beth
2016-01-27T20:26:16+00:00
Hi everyone. We just released a new update that should resolve the following formatting/selection issues:
  • Sections that should be indented, are not indented
  • Tabs no longer display correctly
  • Strange pieces of characters are left on the screen
  • Selection range is incorrect, (Word doesn't select the text you choose)
  • Bullet and Number Lists don't display correctly
For more information, see: FIXED 1/26/16: Word 2016 doesn't display your document formatting correctly when you edit a document in progress.
Please try it out and let us know if you run into any trouble.
Thank you.
2016-01-23T19:11:44+00:00
Yes, these all sound like part and parcel of the same bug. The symptoms are:
  • Strange pieces of characters are left on the screen (i.e., the screen painting issue)
The good news is that the fix for the bug has already gone out to our Office Insider audience, which means that it should roll out to the rest of you soon. Here's a bit more info about how the Office 365 updates work: How do I get the newest features in Office 2016 for Office 365?
I also want to take a moment to say that we appreciate each of you reporting your issues and working with us to resolve these bugs. We are listening closely.
57 additional answers
    2016-01-14T17:17:08+00:00
    You can send a document to me and I will see what happens with it in both 2013 and 2016.
    I understand that toggling the display of non printing characters by clicking on the Show\Hide button (¶) on the Home tab of the ribbon, which causes the screen to be "re-painted" has the effect of restoring the indents and I also understand that the indents are dealt with correctly when the document is printed.
    Thanks for the offer. However, I'm going to try a couple other things first to see if I can get my display the way I want it. I also have a machine with an earlier version of Word in the house so I can do a simple check myself.
    I'll report back with any interesting results. But that will be later today. I really need to do some actual writing this afternoon.
    I may end up going back to W2013, but I like the help feature in W2016 and I have an add-on program I don't want to lose. So this will be my last resort.
    I've heard via someone who's been discussing this issue on another forum that MS engineers are now working on this problem. I'm very glad to hear that.
    If anyone knows when that fix might be coming, I'd like to know.
    2016-01-17T01:34:15+00:00
    Hi everyone. Here is official confirmation of the issue, in case you haven't seen it yet. We'll notify you immediately when the fix goes out.
    • Anneliese
    2016-01-21T02:48:24+00:00
    I'm very glad to hear it. I've been having this problem as well, and as I'm in the process of negotiating a contract, the last thing I need is to appear unprofessional by turning in incorrectly formatted work or requesting that my editor use a different program from the industry standard.
    Any idea how long this update will take?
