Clipboard problem in Excel 2016
2016-04-16T23:39:19+00:00
I am running Excel 2016 on a Windows 10 Machine.
When I copy a cell (or cut a cell, or move a cell) I get one of two error messages:
"Cannot open the Clipboard"
"We couldn't free up space on the Clipboard.  Another program might be using it right now."
I am then able to successfully paste what Excel told me it could not copy.  To restate for clarity...Excel throws error messages, but I am able to successfully copy and paste.
The problem is that it throws the error messages every single time I try and copy or cut or whatever.
Things I have tried:
I've ensured all other programs are not running (or using the clip board)
I've cleared the %temp% folder
I've cleared the Clipboard within Excel
Word does not have this problem...
Please help.
2017-02-28T16:18:02+00:00
I have an update on this error dialog: “There's a problem with the clipboard, but you can still paste your content within this workbook."
When Excel shows this dialog after a copy (CTRL+C) action, it means that another app has a lock on the system clipboard.  In this situation you can still paste within Excel.  However you cannot paste to another app like Word or Outlook which uses the clipboard.
Last year we made some improvements to Office365 users so that this error message only shows once per Excel instance.  This is based on customer feedback - the design change prevents it popping up multiple successive times when the clipboard is locked.  We have also considered never showing the error dialog, but there was user feedback that this message is informative and helpful in some cases.
We hope this helps shed some light on this error message.  For any design suggestions or new ideas on improving the Excel copy-paste experience, please post to Excel UserVoice.
255 additional answers
    2016-07-05T20:55:42+00:00
    This problem seem to be cropping up frequently and there are many threads all over the web outlining the issue.  I find it hard to understand why MS does not seem to openly recognise the issue and get it sorted.  Particularly when it is caused by their own programmes?
    I can replicate the problem 100% of the time by taking the steps outlined in mark_aok's comment.  if I then close Outlook the problem disappears.  I can't be certain that other programmes won't cause the same error but closing Outlook seems to solve it for me.  Not a good solution as Outlook is normally open and running 100% of the time I am logged on. I am running Outlook 2016 from O365HomePremRetail (all updates installed) on Win 10 64 bit.
    If you can't sort it for all programmes, please MS for goodness sake stop your own programmes from causing the issue!  How about a public statement from the programme developers on this forum?
    2016-07-07T20:52:28+00:00
    Hi Chris,
    I’ve checked with the Excel team and there is more than just one issue which leads to this message. The problem where an outside application does not release the Clipboard will remain. However, we can make it much less annoying. We are working on a new and clearer message that will be displayed just once, instead of on each attempt to copy.
    We'd love to get more information about the Microsoft programs that cause this problem. Can you please tell us specifically how to repro that? We will absolutely investigate that further.
    Freya
    Office Newsroom
    2016-07-08T07:01:32+00:00
    Thank you Freya for at least confirming that the issue is acknowledged and the team is trying to find a solution.
    As far as replicating the issue is concerned.  This morning I tried again.
    Windows 10 64 bit fully patched.  Excel from Office 365 HomeRetPrem V16.0.7070.2022
    Open Outlook.  (No other programmes running other than a few background processes)
    Open Excel to blank worksheet
    Select cell, click Ctrl C to copy
    With mouse drag copied cell to adjacent cell and release
    Error message  as below appears.
     ![](http://fud.community.services.support.microsoft.com/Fud/FileDownloadHandler.ashx?fid=214a2ae3-b6fa-4292-afa0-0c4e1ebd6f39)
    Close Outlook and repeat above process
    No error message appears.
    I admit this does not happen 100% of the time.  I then reopened Outlook and repeated the copy and past of a blank cell and no error occurred the first time but it did a short while later after Outlook had run "Send and receive" a couple of times.
    I never had this problem when using Office 2013.  It only started using Office 2016 (via O365).
    One key point is that although you get various error messages, the actual copy to clipboard always seems to succeed in spite of the message.  Once you click "OK" on the message, you can always paste whatever you copied without any issues.  It is not the copy function that seems to be failing, it is the generation of the false and misleading message that is the real problem.
    I hope this is of some help?
    Regards, Chris
    2016-07-08T17:35:29+00:00
    Thank you, it absolutely helps! I'll let the team know.
    Once we release the fix, I'll let you know that as well.
    Freya
