Clipboard problem in Excel 2016
2016-04-16T23:39:19+00:00
I am running Excel 2016 on a Windows 10 Machine.
When I copy a cell (or cut a cell, or move a cell) I get one of two error messages:
"Cannot open the Clipboard"
"We couldn't free up space on the Clipboard.  Another program might be using it right now."
I am then able to successfully paste what Excel told me it could not copy.  To restate for clarity...Excel throws error messages, but I am able to successfully copy and paste.
The problem is that it throws the error messages every single time I try and copy or cut or whatever.
Things I have tried:
I've ensured all other programs are not running (or using the clip board)
I've cleared the %temp% folder
I've cleared the Clipboard within Excel
Word does not have this problem...
Please help.
2017-02-28T16:18:02+00:00
I have an update on this error dialog: “There's a problem with the clipboard, but you can still paste your content within this workbook."
When Excel shows this dialog after a copy (CTRL+C) action, it means that another app has a lock on the system clipboard.  In this situation you can still paste within Excel.  However you cannot paste to another app like Word or Outlook which uses the clipboard.
Last year we made some improvements to Office365 users so that this error message only shows once per Excel instance.  This is based on customer feedback - the design change prevents it popping up multiple successive times when the clipboard is locked.  We have also considered never showing the error dialog, but there was user feedback that this message is informative and helpful in some cases.
We hope this helps shed some light on this error message.  For any design suggestions or new ideas on improving the Excel copy-paste experience, please post to Excel UserVoice.
255 additional answers
    2016-12-29T11:19:20+00:00
    Thanks for the hint DesCarrol and Anthony208. But how exactly do I turn off Zone Alarm? Is it integrated in Windows 10? I repeat, I have absolutely no programs installed except first update of Windows 10, and of course, MS Office.
    2016-12-29T11:32:19+00:00
    OK, I understand.  I did not have a virgin environment.  At the outset I added Zone Alarm (third party anti-virus) so was able to uninstall it (although I kept the exe file).  In your case it seems to be back to square one.  Have you been able to get a MS tech remote into your PC to help you explore the issue?
    Regards,
    Des
    2016-12-29T12:56:11+00:00
    No, I didn't get MS tech remote. As far as I could see, Microsoft crew is following this topic and they are working on this issue. I am not sure why does it take so long for them to solve it. Today I got tons of updates (especially for MS Office) and the problem still persists.
    Now there is even more intriguing fact. My cousin is also using Windows 10 with MS Office 2013 and he is not experiencing clipboard problem?! This could only lead us to conclusion that no program/procedure rolling in the background of Windows 10 is causing problem. It could only be due to driver for Windows 10 which is specific for laptops experiencing this problem.
    I will get back to this when I have more information. Thanks a lot for your help.
    Yes, I will try MS remote help as well.
    2016-12-29T18:57:22+00:00
    If you bought a new car and had problems with it, would the manufacturer expect you to fix it yourself? Would you sit there for hours trying to fix it yourself? I think not.
    The amount of hours that people are wasting 'fixing' or trying to overcome Microsoft problems is astronomical.
    There are loads of problems with the 'new and improved' (sic) Windows 10. It is unbelievable.
    Microsoft should be ashamed (or if they are, they don't seem to give a damn).
    Steve
