Clipboard problem in Excel 2016
2016-04-16T23:39:19+00:00
I am running Excel 2016 on a Windows 10 Machine.
When I copy a cell (or cut a cell, or move a cell) I get one of two error messages:
"Cannot open the Clipboard"
"We couldn't free up space on the Clipboard.  Another program might be using it right now."
I am then able to successfully paste what Excel told me it could not copy.  To restate for clarity...Excel throws error messages, but I am able to successfully copy and paste.
The problem is that it throws the error messages every single time I try and copy or cut or whatever.
Things I have tried:
I've ensured all other programs are not running (or using the clip board)
I've cleared the %temp% folder
I've cleared the Clipboard within Excel
Word does not have this problem...
Please help.
2017-02-28T16:18:02+00:00
I have an update on this error dialog: “There's a problem with the clipboard, but you can still paste your content within this workbook."
When Excel shows this dialog after a copy (CTRL+C) action, it means that another app has a lock on the system clipboard.  In this situation you can still paste within Excel.  However you cannot paste to another app like Word or Outlook which uses the clipboard.
Last year we made some improvements to Office365 users so that this error message only shows once per Excel instance.  This is based on customer feedback - the design change prevents it popping up multiple successive times when the clipboard is locked.  We have also considered never showing the error dialog, but there was user feedback that this message is informative and helpful in some cases.
We hope this helps shed some light on this error message.  For any design suggestions or new ideas on improving the Excel copy-paste experience, please post to Excel UserVoice.
255 additional answers
    2016-11-17T09:35:57+00:00
    Hello Freya,
    I can confirm that I am also seeing this new pop-up message "There's a problem with the clipboard, but you can...". I see it only in Excel 2016. I am running Windows 10 1607 14393.447, Excel 2016 (Office 2016 version 1610 build 7466.2038) on a recent clean install of Windows 10 and Office 2016 with not much 3rd party software. In my case, roughly 1 out of 4 CTRL+Cs results in this message. However, I do not get it just once - I get it repeatedly. Rapid CTRL+Cs seem to provoke it especially.
    As others have suggested, on my system, I have traced it down to another application intercepting the clipboard - in my case, it was VirtualBox. Shutting down all VirtualBox VMs immediately fixes the problem in Excel, but having one or more VMs running, even if the host-guest clipboard integration feature is disabled in that VM, causes the problems in Excel.
    I will raise this with VirtualBox. However, anecdotally, many applications that hook in to the clipboard (eg. Skype click to call integration and others) seem to upset Excel specifically (and not just version 2016). This is not just an Excel issue, but it seems from Freya's comments that the Excel team is aware of it, and trying to mitigate it somewhat. If this message could genuinely come up once per session, or be optionally dismissed permanently, that would be preferable.
    2016-11-18T11:24:46+00:00
    I know this is not helpful, but I think it is absolutely disgusting that the team at Microsoft, with all the resources they have to hand, cannot fix this ALARMING issue.
    This problem breaks Excel automation. This is causing untold havoc to many users. I know because I am getting flooded with calls!.
    You come across as though you are all concerned about this problem, BUT YOU ARE NOT FIXING THE PROBLEM. When you say you cannot reproduce the problem your end, then that is just incredible.
    It is disgusting. You should stop selling the software until you get it fixed.
    Steve
    2016-11-18T16:42:03+00:00
    Agreed.  The comment is only helpful to the extent Microsoft realizes and fixes the blunder as a result of hearing our outrage.
    When I ran Windows 7, Office 2007, and Adobe Acrobat XI, I had no troubles for years and years.
    Under pressure--remember the multiple pop-ups per day?--I "upgraded" to Windows 10.
    Not to bore you will details of snowballing difficulties as a result of "upgrade," suffice it to say that I agree with the sentiment of the previous contributor.
    In sum: ****?
    2016-11-28T19:35:20+00:00
    Hello
    I have the same problem, but  I am using the last version of Excel 1610 (7466.2038)
    Please some help.
