Clipboard problem in Excel 2016
2016-04-16T23:39:19+00:00
I am running Excel 2016 on a Windows 10 Machine.
When I copy a cell (or cut a cell, or move a cell) I get one of two error messages:
"Cannot open the Clipboard"
"We couldn't free up space on the Clipboard.  Another program might be using it right now."
I am then able to successfully paste what Excel told me it could not copy.  To restate for clarity...Excel throws error messages, but I am able to successfully copy and paste.
The problem is that it throws the error messages every single time I try and copy or cut or whatever.
Things I have tried:
I've ensured all other programs are not running (or using the clip board)
I've cleared the %temp% folder
I've cleared the Clipboard within Excel
Word does not have this problem...
Please help.
2017-02-28T16:18:02+00:00
I have an update on this error dialog: “There's a problem with the clipboard, but you can still paste your content within this workbook."
When Excel shows this dialog after a copy (CTRL+C) action, it means that another app has a lock on the system clipboard.  In this situation you can still paste within Excel.  However you cannot paste to another app like Word or Outlook which uses the clipboard.
Last year we made some improvements to Office365 users so that this error message only shows once per Excel instance.  This is based on customer feedback - the design change prevents it popping up multiple successive times when the clipboard is locked.  We have also considered never showing the error dialog, but there was user feedback that this message is informative and helpful in some cases.
We hope this helps shed some light on this error message.  For any design suggestions or new ideas on improving the Excel copy-paste experience, please post to Excel UserVoice.
255 additional answers
    2016-09-28T16:58:02+00:00
    I am getting similar problems with Excel, version 16.0.7341.2032 and also now with the newer 16.0.7167.2060.
    I have also seen a message which I don't think has been reported here:
    "There's a problem with the clipboard, but you can still paste your content within this workbook. "
    ![](http://fud.community.services.support.microsoft.com/Fud/FileDownloadHandler.ashx?fid=2b51e39d-fa53-4307-aa83-2d49c487bd82)
    As reported elsewhere the paste still seems to work correctly.
    This is actually the solution you are seeing! :)
    Excel cannot control what outside applications do to consume all the clipboard space. As you can see from the posts where people remove other apps and Excel is happy again, the problem is not caused inside Excel. What Excel changed is the behavior when in this state. Instead of giving you an annoying error message each and every time you try to copy/paste something, we give this new message just once. That way you know what's going on, but you can continue to work within Excel without the constant interruptions.
    Please let us know what you think!
    Freya
    Office Newsroom
    2016-10-02T04:16:36+00:00
    I had the exact same issue.  In addition, after this error appearing once or twice, Excel would lose the cursor. I ran the manual update.  Error has changed to "There is an error with the Clipboard, but you can keep pasting..." and the lost cursor issue has not, yet, reared itself, again.
    2016-10-26T15:57:23+00:00
    would love to try this, but...
    How do we know if 16.0.7341.2032 is already installed?
    How do we update to 16.0.7341.2032 if it is not already installed.
    note: buying into the subscription service was meant to include such updates and avoid silly errors like the one(s) mentioned on this thread.  right?
    2016-10-27T05:36:04+00:00
    I think you are right about this being a cut and past issue rather than a clipboard issue.
    I use Windows 10 Pro with Office 365 and Excel 2016 on the desktop running on Suface Pro 4 with i7, 16GB RAM, 512 SSD, so plenty of capacity.
    I have elsewhere reported that I not only receive these messages (only in Excel) but also lose cell boundaries after cutting and pasting, ie, the cursor cannot identify a cell, in which case I have to find the corner of the cell then drag down as if copying to recover the boundary.
    In addition, often after filling a cell with colour I lose control by the cursor and have to log out of Excel and log in again to regain cursor use.  This problem has persisted for a year now and it is truly pathetic that it has not been resolved yet, especially since so much reliance is placed on Excel by business users.  I also use a W7Pro PC with Office 2010 and have never problems like this.  Google Apps are gaining traction all the time and MS needs to more responsive to these issues if it is to retain its customer base.
