Clipboard problem in Excel 2016
2016-04-16T23:39:19+00:00
I am running Excel 2016 on a Windows 10 Machine.
When I copy a cell (or cut a cell, or move a cell) I get one of two error messages:
"Cannot open the Clipboard"
"We couldn't free up space on the Clipboard.  Another program might be using it right now."
I am then able to successfully paste what Excel told me it could not copy.  To restate for clarity...Excel throws error messages, but I am able to successfully copy and paste.
The problem is that it throws the error messages every single time I try and copy or cut or whatever.
Things I have tried:
I've ensured all other programs are not running (or using the clip board)
I've cleared the %temp% folder
I've cleared the Clipboard within Excel
Word does not have this problem...
Please help.
2017-02-28T16:18:02+00:00
I have an update on this error dialog: “There's a problem with the clipboard, but you can still paste your content within this workbook."
When Excel shows this dialog after a copy (CTRL+C) action, it means that another app has a lock on the system clipboard.  In this situation you can still paste within Excel.  However you cannot paste to another app like Word or Outlook which uses the clipboard.
Last year we made some improvements to Office365 users so that this error message only shows once per Excel instance.  This is based on customer feedback - the design change prevents it popping up multiple successive times when the clipboard is locked.  We have also considered never showing the error dialog, but there was user feedback that this message is informative and helpful in some cases.
We hope this helps shed some light on this error message.  For any design suggestions or new ideas on improving the Excel copy-paste experience, please post to Excel UserVoice.
255 additional answers
    2016-09-22T22:21:49+00:00
    Hello! We've released a build that should include improved behavior for this situation. Can you please update to 16.0.7341.2032? Let us know if the issue recurs after updating.
    Thank you so much for your patience!
    Freya
    Office Newsroom
    2016-09-28T10:29:46+00:00
    I am getting similar problems with Excel, version 16.0.7341.2032 and also now with the newer 16.0.7167.2060.
    I have also seen a message which I don't think has been reported here:
    "There's a problem with the clipboard, but you can still paste your content within this workbook. "
    As reported elsewhere the paste still seems to work correctly.
    2016-09-28T16:02:42+00:00
    ![](http://fud.community.services.support.microsoft.com/Fud/FileDownloadHandler.ashx?fid=2b51e39d-fa53-4307-aa83-2d49c487bd82)
    I have erased the problem by removing the program/apps Zone Alarm.  I have not installed the new version and Excel is working like a charm.
    2016-09-28T16:06:22+00:00
