Powerpoint Office2016 Eyedropper not working
2015-12-01T17:51:55+00:00
Hi
just upgraded last week to Office2016/64 on Win10 and discovered that the eyedropper in the color picker in PowerPoint no longer works. No matter where on the screen I put the cursor I get a gray color as opposed to the color immediately under the cursor as in Office365/2013/64 Powerpoint
help!
2017-06-26T15:35:44+00:00
I, too, had this problem. Ran Office 365 ProPlus "Office Updates", which took PowerPoint from Build 7369.2130 up to 7766.2092, and the eyedropper issue is now non-reproducible on my machine. Seems if you can do the updates, you should be good to go.
For those who might not be able to update Office, or do and still see the issue, here's a workaround that's not too painful: The issue only seems to affect colors in the PowerPoint application; I was able to pick colors with the eyedropper from other apps just fine. (To do this, after activating the eyedropper tool, click anywhere in a PowerPoint slide, then hold and drag the mouse to anywhere else on your desktop; release the mouse button when over the desired color.) So, to pick a color that's on the slide, screenshot the slide, then use the eyedropper to pick the desired color from the screenshot.
Hope that makes sense...
91 additional answers
  1. Steve Rindsberg 99,176 Reputation points MVP Volunteer Moderator
    2016-02-20T18:20:59+00:00
    >> It has nothing to do with the magnifier.
    In the sense that there seem to be other causes, yes.
    In the sense that the magnifier can trigger the problem, no.  Since turning it on and off *definitely* can make the problem appear/disappear, I'd hate to give anyone the impression that they can ignore the magnifier and look for other solutions when that might, in fact, be it.
    For them.
    Clearly, not for everybody.
    If you can locate any other causes, please let us know here.  I've been funneling information about the problem to the people at MS who are working on it.
    2016-02-20T18:28:33+00:00
    I don't know that I have ever run the magnifier. Maybe I have in the year I've had this computer, but I'm not really aware of having done so.
    2016-02-20T19:41:03+00:00
    Vard,
    Re: PPT Eyedropper
    I tried your steps.  No change, no joy!
    The magnifier was off, I recycled, tried, no change; rebooted, no change.
    Keep the pressure on!  By the way, it works correctly on Publisher on the same system, so it seems to be unique to PowerPoint.
    Rick573
    2016-02-20T21:36:01+00:00
    Rick573,
    It's the same for me. The eyedropper does work in Publisher, but not in PowerPoint, and I tried the same magnifier steps to no avail.
    -Chris
