KB2553154 Breaks COM and Active X controls in Excel
2014-12-10T14:28:48+00:00
Hi
The last windows update batch contained update KB2553154 for office 32 bit.
This update breaks all COM and Active x controls in Excel (i.e. buttons, combo boxes etc.). Like many businesses we use Excel with these controls extensively and this update is crippling Excel for our users.
We have installed and uninstalled it on a number of machines both Windows 7 and Windows 8 and have proved this update is causing the issue.
PLEASE Microsoft withdraw or fix this update we can hardly go around all our pc's worldwide and manually uninstalling it.
Regards
A customer wondering if you test your updates before releasing them
HansV 462.7K Reputation points MVP Volunteer Moderator
2014-12-10T14:49:07+00:00
Quit Excel.
Start Windows Explorer.
Select the system drive (usually C:).
Use the Search box to search for *.exd
Delete all found files.
(Thanks to Excel MVP RoryA for this tip)
2016-10-18T19:07:46+00:00
I know that this is way beyond when you posted this but I was able to fix this problem by updating Microsoft Office to the latest service pack. Then installing excel2010-kb2956142-fullfile-x86-glb.exe for Office 2010 andexcel2013-kb2956145-fullfile-x86-glb.exe for Office 2013. Hope this might help out someone else out there trying to figure out this problem.  Also this page has some information on fixes as well. https://support.microsoft.com/en-us/kb/3017349
43 additional answers
    2017-05-10T16:40:23+00:00
    Worked like a charm.
    I did a search of the C: and two results were found when searching for .exd.
    MSForms.exd Located in the Users\UserName\appdata\local\temp\vbe
    MSForms.exd located in the C:\users\username\appdata\local\temp\Excel8.0
    I removed the second because it was located int the temp\excel8.0 folder only and the issue was resolved.
    Thanks again.
