A family of Microsoft products that enable users to capture, organize, and reuse notes electronically.
You would have to share from a desktop using the browser, i could not get any sharing option on my Android phone either.
Is it possible to share a note using OneNote on my android phone? There seems to be no "share" menu. I've been an Evernote user and just migrated to OneNote because of it has a much more effective stylus note taking capability. I use it on my Samsung 3 and Samsung Note 10.1. But, I have to continue using Evernote to share articles I've saved into Evernote. I prefer to save everthing into OneNote if possible and only use OneNote.
Yeah I noticed that was shockingly absent as well. Like do they really want to be taken seriously as a competitor to Evernote or not?
Remember back in the good old days when every word processor had a print feature? Well the lack of a share action here is like making a word processor that can't print, essentially. Of course Evernote is off in lalaland as well cause their share usually shares a web link instead of the actual content to the other app.
Share. Export PDF. Export image. Print. Make it so you can do *something* useful, and make it *from the device that is already in the user's hands* or OneNote will continue to be a poorly thought out half-bummed little pet project on Android. As opposed to something I'd want to start using this semester.
Hi Carl,
To share OneNote notebooks on Android, you may sign into the OneDrive account using the web browser.
For information on how to migrate Evernote to OneNote, you may refer to the following Discussion thread and check if it helps.
I hope the above information helps.
Thank you.
Hi Carl,
Thank you.
Thanks... unfortunately, when I sign into my OneDrive account using a web browser on my android phone or tablet, it redirects back to the OneNote application once I click the OneNote folder in OneDrive. This happens regardless of whether or not I use the OneDrive app or access through a browser. I have already migrated from Evernote to OneNote via the link you also suggested. The problem is not getting to my notes it is "sharing" a note from an android device. It appears that the only way to share notes is from a Windows OS computer and converting a note to a PDF and attaching it to Gmail (because I don't use Outlook). Cumbersome.
That's what I thought. I hope MS adds this capability. Without it, I have to keep using Evernote alongside OneNote.
