How to get images to display in draft layout?
2013-08-28T00:11:44+00:00
If I paste an image into a Word document, it is only visible in print layout (page mode), not in draft layout (normal view).
But, if I first paste it into Visio and then paste that image into Word, it is visible in both layouts.
I could not find a way to attach a Word document, so I created a screen shot as a JPG. I couldn't get that to upload (I kept getting "The connection was reset"), so I created a shared DropBox folder containing both the Word document and the JPG image. Here's the link:
https://www.dropbox.com/sh/o9ah4faeul14sq8/6CQUKgWs47
If I select the first image, I see square handles. If I click on the second image, I see round handles. Clearly, these images are being stored in different formats.
My question is : How can I get all images to display in both print and draft layout?
The "Show picture placeholders" option is not checked.
    2016-04-26T09:10:10+00:00
    On the contrary, the fact that you are still wittering on about this, three years on, merely suggests that your mother-in-law has you correctly summed up.
    2016-10-05T12:47:41+00:00
    > Why not work in Print Layout mode? That will show graphics. Frankly there is little justification for working in draft mode with modern PC hardware.
    Because I want to see the text and not the layout.  I'm trying to get text written and don't need to see formatting,  page breaks and other irrelevant noise.  What I do need to see is the images.
    Your argument is based on 1990's logic,  not creating content.
  3. Stefan Blom 352.7K Reputation points MVP Volunteer Moderator
    2016-10-05T13:00:37+00:00
    What you can do is post feedback for Microsoft in the Uservoice forum at http://word.uservoice.com. No one here is in a position to make decisions on Microsoft's behalf.
    2016-10-05T18:11:10+00:00
    Have you tried "web layout" view ...
    I work in it all day long, switching to outline view periodically.  Page layout view is essentially useless to me because I rarely print documents today, so I don't need to see "paper margins" and "page breaks"
