"Feature appears to be broken" - Cannot Repair (Help)
2014-05-15T10:46:12+00:00
I have recently bought Microsoft Office 365 University.
After installing it correctly, I went to access Microsoft Word. While loading the program the notification came up: "We're sorry but this feature appears to be broken and needs to be repaired. Use the programs and features option in the windows control panel to repair Microsoft office".
After clicking "OK" the program loaded and then this notification popped up:
I proceed afterwards to try both the quick repair, and the long repair options that Microsoft has to offer, and have no luck fixing my problem.
I can not find help on the faq, or support services.
Any useful information would be appreciated, thank you.
2014-12-07T00:21:07+00:00
Had the same problem either. After check  to support.office.com its says there 4 add-in that may cause the problem:
ABBYY FineReader, Broadcom Send-to-Bluetooth, Intel Send-to-Bluetooth, and KingSoft’s PowerWord. I just uninstalled WPS KingSoft and this buggy message things gone for goods.
2014-05-22T11:46:44+00:00
Try the steps below and check the result:
You may run the fix it tool mentioned in the link below to remove the traces of Office completely from the computer.
http://support.microsoft.com/kb/2739501
Once the traces are removed, restart the computer and reinstall the Office suite.
Let us know the result.
Thank you.
Stefan Blom 353.5K Reputation points MVP Volunteer Moderator
2017-03-15T20:33:04+00:00
I am now at my wits end with microsoft, I have installed Office 365 and paid the fee, to find I now cannot get access after endless attempts all afternoon, it appears it needs some repair. Is there a solution.
If you also have WPS Office installed, as mentioned by other posters here, you may want to try uninstalling it.
For instructions on repairing Microsoft Word, see "Repair an Office application" at https://support.office.com/en-us/article/Repair-an-Office-application-7821d4b6-7c1d-4205-aa0e-a6b40c5bb88b?ui=en-US&rs=en-US&ad=US&fromAR=1.
41 additional answers
    2014-12-30T16:33:44+00:00
    Same problem here.  I ran the fixit tool several times.  Made sure all Wifi and Bluetooth programs were uninstalled.  The issue keep appearing again after reinstalling Word.  Any help Microsoft?
  2. Doug Robbins - MVP - Office Apps and Services 323.6K Reputation points MVP Volunteer Moderator
    2014-12-30T22:05:01+00:00
    A lot of problems with Office 2013 are caused by third party (non-Microsoft) applications.  This is my (expanding) list of things to try when Office 2013\365 won’t start or crashes: See the Article “Why can’t I start my Office 2013 application at: http://office.microsoft.com/en-us/support/why-cant-i-start-my-office-2013-application-HA104011864.aspx For the error message Error: "Microsoft Office cannot verify the license for this product." See:
    http://support.microsoft.com/kb/2797062/en-us
    Refer to the following website for information on repairing Office 2013\365:
    http://office.microsoft.com/en-us/project-help/repair-or-remove-office-2010-HA010357402.aspx
    See Office 2013 install woes - http://office-watch.com/t/n.aspx?a=1834
    See the KnowledgeBase article “Office 2013 applications crash on launch at the splash screen” at:
    http://support.microsoft.com/kb/2813143
    Or see the KnowledgeBase article Error: “Something went wrong and we can't sign you in right now” when trying to install Office 2013 at:
    http://support.microsoft.com/kb/2811180/en-us/
    Try to run word in safe mode by typing winword/safe. If thatdoes not helpthen, in the search box type winword --> Word 2013 will be displayed --> right click on it --> Select Properties --> Go to the compatibility tab --> Check to see if there is a check mark next to compatibilty mode. If it is checked then uncheck it and then uncheck the option of Run as Administrator if its checked. Now run the word Also see my response in
    http://answers.microsoft.com/en-us/office/forum/office\_2013\_release-word/microsoft-word-2013-has-stopped-working/67b81016-849f-481a-bce5-bf04797ac03b
    Do you have Abbyy Finereader installed on the PC? A number of people have reported that removing it overcomes problems with 2013.  See:
    Office programs may crash with the FineReader add-in installed at:
    http://support.microsoft.com/kb/2755838
    Do you have “Fun Tools” add-in? A number of people have reported that removing it overcomes problems with 2013
    Do you have Toshiba Book Reader installed on the PC?  It has been reported that uninstalling that brings Office back to working status.
    Do you have the Acrobat PDFMaker add-in.  It has been reported that uninstalling that overcomes an issue with a message appearing that states "The document contains macros. Macro support for this application is disabled. Features requiring VBA are not available. Would you like to open this document as a read only?"
    Also see: http://answers.microsoft.com/en-us/office/forum/office\_2013\_release-word/microsoft-word-has-stopped-working-when-i-close/8375b5b6-4f7e-46ed-a02b-90152ecad287#LastReplyand
    http://answers.microsoft.com/en-us/office/forum/office\_home-word/word-and-excel-2013-crashing-on-windows-7/5389390c-e989-4c8e-8fe0-62673f1410ce?page=4#LastReply
    It appears that there may be some hardware incompatibilities as well.  If you have the NVIDIA driver NVWGF2UM.DLL, try renaming it as: NVWGF2UM.oldas was mentioned in:
    From the File tab, select Options and then click on Advanced and then in the Display section of the dialog, check the box for Disable hardware graphics acceleration
    For the error message "There was a problem sending the command to the program", use Windows Explorer to access the C:\Program Files\Microsoft Office\Office15 folder and right click on WINWORD.EXE then on Properties, go to the Compatibility tab and uncheck all the boxes.  It has also been reported that the problem can be overcome by editing the registry at HKEY_CLASSES_ROOT\Word.Document.12\shell\Open and deleting the ddeexec key.
    The ddeexec can also be deleted from
    HKEY_CLASSES_ROOT\Word.DocumentMacroEnabled.12\shell\Open.
    That fix is described at ...
    http://www.dilloway.co.uk/there-was-a-problem-sending-the-command.htmlIt has been reported that uninstalling FastPictureView and FastPictureViewer Pro… overcomes the issue of the Minimize, Maximize, Close and Help buttons not being visible in Office 2013.
    If you have a Canon 8350 printer, try using the Canon MF8000 UFRI LT XPS driver as detail in the post by Riad Amstha on April 14 in the thread at:
    http://answers.microsoft.com/en-us/office/forum/office\_365hp-word/office-2013-crashes-with-canon-8350-printer/e2bf6530-92e0-47ef-b6ec-e803a91793d0?page=3#LastReply
    For the problem of nothing appearing when you start typing in a blank document in Word in Office 365 Home Premium, and you hear a bell sound with each keypress, but no characters appear, disable the SMARTInk add-in for an interactive whiteboard.
    If none of that helps, then you might remove all traces of the Office installation by downloading the fixit from the following article:
    http://support.microsoft.com/kb/2739501 saving it to your computer and then running it.
    Then reinstall Office by logging into www.office.com/myaccountwith your registered email address and click Install Office.
