Cut/Copy and Paste Problems in PowerPoint
2013-09-30T02:03:09+00:00
PowerPoint will not allow me to paste anything into a slide.  I have tried text into a text box, shapes, entire slides.  It allows me to copy or cut, but when I try to paste it is greyed out or does nothing when I use Command+V on my MacBook Pro.  I am running Office 2011 Home & Student and copy and paste work fine in Word and Xcel.  I have tried to reinstall the software and that didn.t help either... Any ideas?
71 additional answers
    2013-10-25T19:45:28+00:00
    I created the account like listed here and it did not fix the problem.  I tried playing with preferences and settings both in the MSOffice and the iOS settings - none of this worked to fix the problem.  I uninstalled and reinstalled MSOffice, and that didn't work.  I reloaded my iOS operating system and that didn't fix the problem.  I upgraded my MSOffice from Student to Business and that didn't fix the problem.  I went to Apple and had them do a bare metal restore of my machine and then reload the app from scratch - that didn't fix the problem.
    The only thing that I have done that fixed my problem, really isn't a fix ... I bought Apple's Keynote, and now I import .ppt into Keynote when I need to cut and paste objects and then I convert back to .ppt.
    There is some type of a bug in the MSOffice application and PowerPoint.  I have eliminated everything else.
    2013-10-25T19:46:42+00:00
    No, the problem is still there.  There is some type of a bug in the MSOffice application and PowerPoint.  I have eliminated everything else.
    2013-11-01T23:06:50+00:00
    I have exactly the same problem. Cut/Copy and Paste works perfectly in Word and Excel but not in Powerpoint. It also works from Word/Excel to Powerpoint.
    When I copy something in Powerpoint, it goes as expected to the system clipboard (I checked it with Finder -> Edit -> Show clipboard) but the Paste menu is always disabled or a bell rings with Commande+v.
    2013-11-02T13:04:17+00:00
    same problem here, can't paste in Powerpoint.
