Cut/Copy and Paste Problems in PowerPoint
2013-09-30T02:03:09+00:00
PowerPoint will not allow me to paste anything into a slide.  I have tried text into a text box, shapes, entire slides.  It allows me to copy or cut, but when I try to paste it is greyed out or does nothing when I use Command+V on my MacBook Pro.  I am running Office 2011 Home & Student and copy and paste work fine in Word and Xcel.  I have tried to reinstall the software and that didn.t help either... Any ideas?
71 additional answers
    2014-08-11T14:34:47+00:00
    I was having the same problem, but was able to solve it.  I'm posting this in hopes that it may help others.
    I turned off Dictation in my System Preferences (under Dictation/Speech) and then rebooted my Mac.  It appears to be working now.
    I have no idea why this worked (I read that the new Dictation is giving random problems, so I gave it a try on this problem).
    Hope this helps.
    Thanks JLS,
    Will see if this works.
    2014-08-15T01:59:39+00:00
    I tried what you did, but didn't work for me.
    Thank you anyway.
    2014-09-08T01:54:20+00:00
    PROBLEM SOLVED
    I have encountered the same problem.. that is, a weird behavior of power point text copy function. (could not copy text box- and even if i use copy command at the menu, it does not show at the clipboard). I have struggled for the whole yesterday to solve out the problem, tried every way suggested by this thread, and it did not work out. - a big frustration..
    I hit upon an idea, however, that this strange behavior is relatively a new phenomenon, starting to happen around a week ago..
    So, my final try was to delete all the recently installed applications - it was around 5-6 apps, but using an uninstallation software to complete remove the hints of those recently added softwares.. , and relanched the power point..
    Voila!!!!
    IT CAME BACK TO NORMAL,
    I am nothing to do with software development etc.. and a just a normal user.. but my guess is that one or more of recently installed softwares may have disabled a function to copy text box or similar things at Power point due to a certain conflict between power point and those newly installed softwares..
    Those deleted softwares were all related to improvement of mac performances, and a software to edit xml files etc etc..
    Hope this may help to solve the problem
    Thanks to everyone who has participated in this investigation. I’ve alerted Microsoft to the problem. It definitely seems to be related to PowerPoint on certain hardware.
    If you are affected and have direct Microsoft support, please contact them so additional cases can be added to their case logs. If you don’t have direct support, go to the PowerPoint Help menu and choose the send Feedback option to display the feedback form. Explain the details of your hardware, os, powerpoint version and describe the problem. You might copy the URL of this thread and paste that in as a reference. Microsoft doesn’t generally reply to the feedback submissions, but if you include your contact information in your feedback at least they could contact you if they wanted to.
    Hi, is this problem resolved ? I have a MacBook Pro in the office which is having exactly the same issue and can't seems to resolve it.
    2015-01-20T09:01:30+00:00
    Hi Rudi,
    Thanks for the information.
    Still, no one has mentioned what version of Mac OS X is being used or what sort of hardware this happening on. Trackpads? Laptops? Desktops? Certain keyboards? In order to track this down everyone affected should please reply with system and hardware details so that we can find out what is in common with machines that are affected.
    Is everyone using a US English setup?
    Firstly, please add me to the "tiny handful" list.
    Secondly, no, I am using Swedish keyboard and Swedish version of Office 2011.
    Third, I am currently using Yosemite, but the problem goes back to at least Mavericks.
    Most importantly, I have just purchased a brand new macbook pro, with a brand new edition of MS office.
    The entire environment is a clean install.
    I have the same problem on both my old and new laptops.
