Cut/Copy and Paste Problems in PowerPoint
2013-09-30T02:03:09+00:00
PowerPoint will not allow me to paste anything into a slide.  I have tried text into a text box, shapes, entire slides.  It allows me to copy or cut, but when I try to paste it is greyed out or does nothing when I use Command+V on my MacBook Pro.  I am running Office 2011 Home & Student and copy and paste work fine in Word and Xcel.  I have tried to reinstall the software and that didn.t help either... Any ideas?
71 additional answers
    2013-09-30T12:01:25+00:00
    Looks more like a preference issue, try a new user account and see if that helps.
    2013-09-30T14:09:14+00:00
    I went into Preferences from my name to my initials and it didn't help or fix the problem.  Was that what you suggested - just changing the user name in preferences?  Or, is the account changes in another place?
    2013-09-30T14:47:07+00:00
    Sorry for not being clear, i wanted you to create a new one and test it there.
    http://support.apple.com/kb/HT3309
  4. Jim G 134.1K Reputation points MVP
    2013-10-07T15:40:05+00:00
    Hi
    Did opening the file in a new user account result in the problem going away?
