A family of Microsoft word processing software products for creating web, email, and print documents.
No change for me. Plus, my problem includes a loss of the commentor identification, not just text.
So I've spend long hours addressing student coursework, giving comments on their projects. They said the comments wouldn't work so I re-opened their documents and they appear to be correct. Where are all my comments gone? The actual comment boxes are still there but they are empty. This is incredibly annoying. Can I get them back or have they gone forever? Screen shot provided for reference.
***Personal information deleted by the moderator. Please see the Microsoft Community Frequently Asked Questions for more information on how you can protect your privacy.*****
Yes, I have been able to restore the comments by accessing the comments.xml component of the file and removing an errant bookmark.
I am not the least bit interested in the content of your document and you can rest assured that I will not make it available to anyone else and will delete it after returning a copy to you.
Many thanks Patricia, this was the best answer and solved my problem.
Trouble is Patricia, the file looks okay until you send it, then the receiving party finds it is missing comments. BTW, you can unzip by changing file extension directly from .docx to .zip - Windows magic (presumably a de-zipper) does the rest.
If you have a file with that problem, send it to me and I should be able to fix it.
If the document is not too large to attach to an email message, send me a copy of it that way, referencing this thread in the covering email message.
Alternatively, upload a copy of the document to the following folder of my OneDrive
https://1drv.ms/f/s!AmuIXmFDy-1a8nP3RpgnYHp-5zXK
and send me an email to the address shown in my signature to let me know that it is there.
