Office iPad and OneDrive Issues - Missing Folders
2014-03-30T04:09:46+00:00
After trying out Office Word, Excel and Powerpoint on my iPad it seems to me that OneDrive integration is broken.
The main problem is that various folders do not show up in the Office Apps on the iPad. These missing folders though do show up in the OneDrive app for iPad.
I've also had the Office Apps lock up when trying to refresh a folder. Either the program locks up and I have to restart it or, the refresh icon just spins forever.
To troubleshoot the issue I've removed the Word app, reinstalled and reconnected my OneDrive account. I've done this a couple of times and each time when I try to view one of my folders, the app hangs. After restarting the app the folder I was trying to view has missing subfolders.
If I add a subfolder after I've viewed the folder in Word (for example) the new folder shows up. However, none of the folders that are missing will ever appear, no matter how many times I try to refresh the folder.
Oddly enough the missing folders are different between Word, Excel and Powerpoint.
My "Mac Docs" folder should have 25 folders. Word shows 16 folders, Excel shows 9 and PowerPoint shows all 25. However, PowerPoint also has trouble refreshing the folder, and after I've removed some folders, its still displaying the removed folders.
Office on iPad has great potential for me, especially with OneDrive integration, however, at this stage it appears to be quite buggy.
Microsoft 365 and Office | Word | For home | iOS
2014-12-17T18:21:52+00:00
Today we shipped an update to Office for iOS which should fully solve the problem of folders/files taking a long time to show up (or never show up).  I apologize that it took a while to get this fix to everyone, but we had to be certain to not cause new issues in the process.
Please retest the issue and let me know if our update fixed your issues and if it didn't then please provide details so that we can investigate.
Thank you for the patience!
Derek
2014-05-13T04:33:54+00:00
I am not sure if this helps you, but it has fixed the problem for me.  I found that the folder types in my OneDrive were set to Picture folders, not Document folders.
By selecting the folder in Onedrive web application, the properties have a "Folder Type" when you click on the change hyperlink it gives you the ability to chnage the type from Pictures to Documents via radio button.
Once I performed this task all of my folders appeared. in the iOS Office Apps.
Seems that OneDrive determines the Folder type, from the content placed into the folder.
50 additional answers
    2014-11-04T06:36:22+00:00
    Totally agree!!! MICROSOFT! DO YOUR HOMEWORK. Over six month later the same issue!!! This is my status yesterday!
    Onedrive
    Office 365
    Regardless of iPhone or iPad
    Also big problems with renaming and moving files! Suddenly they appear although i have deleted them. On and on andn on ...
    2014-11-07T07:58:10+00:00
    Just tried the latest version of Word, version 1.2, and the folder bug that I had reported earlier still persists on OneDrive storage! However if the same data is stored on the newly admitted Dropbox storage then there is no bug! Does this mean that we should all move to Dropbox storage? And do simple editing so that we don’t need a subscription to Microsoft? Guess not, but it would be nice – indeed ever so nice – if Microsoft did something to address this issue.
    To those still interested and demonstrating great patience, all the best, JohnPercy.
    PS: Even despite these folder/file hassles the core of Word is great and a pleasure to use.
    2014-11-10T22:13:32+00:00
    John,
    With the recently updated applications we made a lot of changes (business model change, Dropbox integration, along with iOS 8 and Office for iPhone and many other items).  One of the quieter updates was to improve the calls to get the OneDrive folder/file structure which should fix this problem.
    Let's try one thing, now that the root cause of the issue should be resolved (as long as your apps are up to date), let's get your app to a clean state and try again.
    Go to the App Store and check for updates.
    From the home screen of your iOS device, go to Settings (press the back arrow if one is shown to get to the root) > Word (near the very bottom) > Reset Word > enable Clear All Documents (AFTER you read the warning below) and enable Delete Sign-In Credentials.  Then restart Word.  Once it is restarted you will need to go through the first run experience again where you will sign-in.
    Give the Open tab a little while to fully populate as it sounds like you have quite a bit of data stored on OneDrive.
    Did this solve your issue?
