A family of Microsoft spreadsheet software with tools for analyzing, charting, and communicating data.
Just solved my own issue.
Had to delete the \Office\15.0\Excel\Options via regedit.
Problem resolved.
Hello -
I have an odd issue. No matter if it is a new or existing workbook my insert and delete row/column options are greyed out. The workbook is not protected as this happens for even brand new ones as well. I have searched and cannot locate a solution.
Excel 2013 - Click to run
Windows 8
Any thoughts would be appreciated.
Problem resolved.
Problem resolved.
This solved.. Thank you.
How to do this on Mac?
Looks like your answer helped hundreds, but I am unable to find such directory.
Maybe this happens because of some macro run in the past?
what does this even mean?
