Be careful! Parts of your document may include personal information that can't be removed by the Document Inspector.
2013-09-27T08:26:34+00:00
Hi All
I have an Excel 2013 document that I've been using for over two months and have had no problems with editing or saving it. Today I edit it and than saved it and I received a strange looking error message "Be careful! Parts of your document may include personal information that can't be removed by the Document Inspector."
I have tried to find out any information on what it might be, by using Bing and Google without any success. It looks like I'm the only one who has received this error message. I hope it's not a virus!
Please help
Colin
2013-09-28T02:05:11+00:00
I had the same problem, it's incredibly annoying and there's strangely little posted about it on the interwebs.  Anyway, here's how you fix it: Goto File in the upper left hand corner, then Options > Trust Center > Trust Center Settings > Privacy Options > then un-check the check box that says "Remove personal information from file properties on save", then hit OK.  Hope that helps.
7400+ people found this answer helpful.
58 additional answers
    2015-03-27T12:35:21+00:00
    Thanks lot. It helped me.
    2015-04-09T17:10:24+00:00
    thanks a lot
    2015-05-29T15:18:17+00:00
    I had the same problem.  Thanks for the answer.  The Excel developers are getting too tricky for their own good.  They are starting to act like auto mechanics who don't own a driver's license.  They seem to have lost touch with how people actually use their program.  Too bad.
    2015-08-26T16:57:17+00:00
    excellent tip
