Be careful! Parts of your document may include personal information that can't be removed by the Document Inspector.
2013-09-27T08:26:34+00:00
Hi All
I have an Excel 2013 document that I've been using for over two months and have had no problems with editing or saving it. Today I edit it and than saved it and I received a strange looking error message "Be careful! Parts of your document may include personal information that can't be removed by the Document Inspector."
I have tried to find out any information on what it might be, by using Bing and Google without any success. It looks like I'm the only one who has received this error message. I hope it's not a virus!
Please help
Colin
2013-09-28T02:05:11+00:00
I had the same problem, it's incredibly annoying and there's strangely little posted about it on the interwebs.  Anyway, here's how you fix it: Goto File in the upper left hand corner, then Options > Trust Center > Trust Center Settings > Privacy Options > then un-check the check box that says "Remove personal information from file properties on save", then hit OK.  Hope that helps.
7400+ people found this answer helpful.
58 additional answers
    2014-08-27T21:08:42+00:00
    Thanks for the tip GodeEscherBob!  This pop-up was annoying me for the last two days.
    2014-09-10T08:54:43+00:00
    This isn't a fix, it just hides the problem.
    The dialog is not an "Error", it is an "Informational" message, which is less severe than an error. It just says there "MAY" be personal information in the file.  That is pretty useless, is there is there not personal info.  Who would know better, MS has the inside info to be able to tell us.  This is another fine example of a ****effort.  MS could tell us exactly what and where this alleged personal information is, but they are too lazy to do it right.
    Disabling the informational warning does nothing to remove the personal information, if it is there.
    I had this problem too, and thanks Rohn007 for your best explanation:)
    2014-10-17T13:55:58+00:00
    I had the same problem.
    As guys said, disabling is not a fix. I did not find fix on the internet but much better then disabling error message is copying data to the new workbook.
    I tried to repeat the same process,but second time i did not get the error message.
    Does someone know what can cause this error?
    2015-02-13T23:20:35+00:00
    I agree that it's frustrating; I felt the same. But the problem you bring up is not specific to Microsoft; For one, it's natural that people who can relate well with computers and other people alike are rarer. But it's also a question of priorities, which ultimately goes back to the consumer: Most consumers don't make their buying decisions by usability, but by shiny new features. By the time they get stuck, they grumble a bit, wait till the early adapters who enjoy that kind of challenge post a solution on the internet, and move on.
    One thing I am worried about, though, is that the most popular solution is just to keep personal information in the file properties on save, which seems to defeat the purpose.
