A family of Microsoft spreadsheet software with tools for analyzing, charting, and communicating data.
I had the same problem, it's incredibly annoying and there's strangely little posted about it on the interwebs. Anyway, here's how you fix it: Goto File in the upper left hand corner, then Options > Trust Center > Trust Center Settings > Privacy Options > then un-check the check box that says "Remove personal information from file properties on save", then hit OK. Hope that helps.
