Be careful! Parts of your document may include personal information that can't be removed by the Document Inspector.
2013-09-27T08:26:34+00:00
Hi All
I have an Excel 2013 document that I've been using for over two months and have had no problems with editing or saving it. Today I edit it and than saved it and I received a strange looking error message "Be careful! Parts of your document may include personal information that can't be removed by the Document Inspector."
I have tried to find out any information on what it might be, by using Bing and Google without any success. It looks like I'm the only one who has received this error message. I hope it's not a virus!
Please help
Colin
2013-09-28T02:05:11+00:00
I had the same problem, it's incredibly annoying and there's strangely little posted about it on the interwebs.  Anyway, here's how you fix it: Goto File in the upper left hand corner, then Options > Trust Center > Trust Center Settings > Privacy Options > then un-check the check box that says "Remove personal information from file properties on save", then hit OK.  Hope that helps.
7400+ people found this answer helpful.
58 additional answers
    2013-09-27T18:28:55+00:00
    Hi Colin,
    I had the same thing happen on one of my spreadsheets, so you are not the only one. I just copied the content to a new sheet and it went away.
    Paul
    2013-10-01T15:22:21+00:00
    Thanks, GodelEscherBob.
    After using the document inspector to remove hidden data and personal information from my file, this message began to pop up incessantly at every save (despite autosave, a little compulsive with CTRL+S).
    Highly annoying and unexpected, never would I have found the fix buried in options...
    2013-12-05T02:11:50+00:00
    It maybe a little annoying, but I found this feature absolutely necessary to prevent unintended personal information leakage. There is always a balance between convenience and privacy/security. I once received a job description from a head hunter, the JD was written by their client of course, but from document properties I can clearly see which company is hiring and who wrote this document. This is definitely an unintended consequence of ignoring the privacy settings.
    2014-02-07T17:19:02+00:00
    I fixed it by going to File, Info, Check for issues, and inspect document.
    Keep everything checked and run it.
    Mine came back with no errors and afterwards the message no longer appeared on save.
