Macro to insert an endnote and an EndNote X7 citation
2014-07-17T19:24:44+00:00
I am working on a 200-300 page book using EndNote x7 and Chicago endnotes formatting style. My Notes will be at the end of the book, not at end of a page or chapter. The process works fine but is not productive. For example, if I am editing the document and need to add a new citation on page 3, I do the following:
  1. Insert footnote/endnote on the page I am editing, say page 3
  2. Insert selected citation at end of document
  3. Scroll back to page 3 to continue editing.
What I propose to do is create a macro that has three parts:
1. Prior to inserting a footnote, insert a bookmark named TEMP
  1. Insert the selected citation using Word/Tools/EndNote7/Insert selected citation
  2. Edit/Find/Goto/TEMP
I created the macro, but I cannot get it to work. Is what I am trying to do reasonable and doable? It seems simple, but....
2016-01-03T19:22:44+00:00
Everything is working exactly as it should. Thanks so much for the assistance. Here are the changes I made:
A. Updated Word to 15.17.1
B. Changes suggested by Thomson Reuters support as follows:
  1. Quit Word.
  2. Browse to this folder on your computer: “Hard Drive Name]/Library/Application Support/Microsoft/ Office365/User Content/Startup/Word.” The folders name may vary depending on your system.
  3. Delete the “EndNote CWYW Word 2016.bundle” file if it is still present.
  4. Hold down the "option" key on your keyboard and go to the "Go" Menu and choose "Library". Go to Users:[your login name with the house icon]:Library:Application Support:EndNote.
  5. Delete “EndNote Cwyw Commands.dotm” and “EndNote Online Cwyw Commands.dotm” if present.
  6. Start the EndNote X7 Mac Beta 2. Please verify this is beta 2 by going to the EndNote menu and selecting About EndNote. The version should read “EndNote X7.5p2 (Bld 10976).
  7. Go to the EndNote menu and select "Customizer."
  8. Check the box in front of the "Cite While You Write" option. Click next until the Customizer is finished.
  9. Open a library in the EndNote X7.5 Beta.
  10. Open Word 2016 and check the Ribbon for EndNote X7.
I also rename the Applescript from Option+Control+f to Option+Command+f.
Rich, thanks very much for your great efforts in developing the macro and Applescript. This solution is a nice productivity booster for anyone writing long documents such as books or dissertations.
2015-12-18T23:19:50+00:00
The issue is this piece of code:
 'since the VBA SendKeys command does not work in Office 2011 I had to resort to AppleScript
    Dim MyScript As String
    MyScript = MyScript & "tell application ""System Events""" & Chr(13)
        MyScript = MyScript & "keystroke ""f""" & " using (option down, command down)" & Chr(13)
        'I assigned a custom keystroke to Option+Control+e that would insert a test AutoText
        'If EndNote X7 overrides that built-in keystroke maybe it will work as you desire
        MyScript = MyScript & "delay 0.1" & Chr(13)
    MyScript = MyScript & "end tell" & Chr(13)
    ActiveDocument.Activate
    MacScript (MyScript) 'this executes the above MacScript
Under the new "sandboxing" rules of Apple if you want to be in their store with your "APP" you have to play by their ever changing hedonistic rules. Microsoft has decided to be their BITC@!
As I said previously, I can't take this on right now, in fact I'm only visiting the forum when I need a distraction from what is turning out to be a full time job trying to make Office 2016 for the Mac VBA work for everyone by reporting issues I'm finding directly to the product team. Right now I don't think I'm one of the more popular MVP's in their address book. :-)
What is required to get this working is someone to investigate AppleScriptTask, and figure out how to write and install the script into your machine and then interface it with this VBA code.
And no Dr. John, you never did send me a free copy of your book and I'm not about to pay for one, so... :-)
50 additional answers
    2015-12-24T16:58:21+00:00
    Thanks. I removed GUB files and macro. System is now stable. I also replaced the Part 1 script with the working one (on 2011). My system is now stable.
    2015-12-24T17:13:58+00:00
    Okay. Now try putting back in just the AppleScript macro and switching to the modified Part 1 VBA script. See if that works.
    I'm trying to figure out what happened... on my system the GUB files do not conflict with this new AppleScript routine but obviously something has gone amiss on your machine.
    2015-12-24T19:31:42+00:00
    Progress. Here is the status:
    1. Stabilized system per instructions
    2. Put the script in the com.microsoft.Word folder. I assume that should be the Library folder in HD Mac not under user
    3. Copied new script into Macros
    4. Updated keyboard macros for Part 1 & 2. I had not done that previously.
    5. I opened a file and executed Part 1 macro. Got a Compile error. See attached screenshot.
