Why do some programs not rescale when moving across monitors on Surface 3?
2014-09-19T15:57:18+00:00
One of the nice features of the Surface 3 Pro is that in a multiple monitor setup (which I use a lot), windows will scale when I drag them from my primary display to the external one(s). That is, the scaling that is done to increase the size on the high DPI Surface screen is removed when I drag to en external monitor with a lower DPI. Very nice!
But, while this is nice, it doesn't work for all windows programs. Why? My example is, of all things, PowerPoint. Word is fine. Excel is fine, Firefox is fine, so is Thunderbird, Windows Explorer, etc. But when I use PowerPoint on my external monitor, the ribbon bar takes up 10-15% of the screen! Add to that the menu and such and I have less than 75% of my screen for actual work.
Is there anything one can do to fix this?
2015-05-18T14:41:20+00:00
Thank you for this pointer. Seems that this does, indeed, fix the problem (for me, at least).
For my setup (Windows 8.1, Surface Pro 3, Office 365 - Office 15) the specific instructions are few and simple:
  1. Go to C:\Program Files\Microsoft Office 15\root\office15
  2. Right-click on powerpnt.exe.manifest and change the permission so you can modify the file
  3. Right-click on powerpnt.exe.manifest and open with Wordpad
  4. Change the line
    <dpiAware>True/PM</dpiAware>
    to
    <dpiAware>False/PM</dpiAware>
  1. Save file
(at least with Office 365, you don't need to do anything in the registry as it's already looking at the external manifest file.)
Yes, line 4 seems counter-intuitive, but it's correct. Once you change this to False, Powerpoint will scale moving from high to lower DPI monitors. I've not encountered any other issues, but I've not used it for very long, yet.
Thanks to the previous pointers/authors for this tip.
(Do read
http://www.danantonielli.com/adobe-app-scaling-on-high-dpi-displays-fix/
if you want more details and the history of this.)
76 additional answers
    2014-11-15T19:43:51+00:00
    2014-11-18T17:21:59+00:00
    The same problem with PowerPoint occurs with Internet Explorer. No problem with Google Chrome, but IE has the same scaling issue. And, I agree, that it's fairly ridiculous that there have been no solid communications about this issue regarding a fix, a fix in progress, or anything else in almost a year.
    2015-03-30T15:20:34+00:00
    This is zoomed down to 57%. This is a full-screen screenshot on a 23" monitor. Look how the ribbon and menus take up 25% of the top of the screen!
    Now look at the ribbon compared to an open Word doc.
  4. Steve Rindsberg 99,176 Reputation points MVP Volunteer Moderator
    2015-03-30T19:01:32+00:00
    Here's a thought:
    Near the right end of the Quick Access Toolbar in PowerPoint, there's an icon that looks like a finger touching a target.  Or something like that.
    That lets you switch between Touch and Mouse mode.  When it's in Touch mode, all of your icons and other bits on the ribbon get bigger and take up more room.  Try changing to Mouse mode to see if it affects the situation.
    I don't have a tablet myself, so can't test this here.
