Why are my onedrive documents opening in read-only mode after installing office 365 home edition?
2014-03-26T17:51:19+00:00
I'm opening a word document from my Onedrive folder on my local machine and it's opening in Word 365 in read-only mode. Why is this  and why can't I open the document in Word 2010?
    2014-10-04T12:54:32+00:00
    I went in and accessed the One Drive folder from c: users/owner/one drive
    Right Clicked on the folder and added to my library.
    So far, after doing this my Word Documents started opening correctly again... I hope the fix sticks!
    knock on wood.
    I think I found the problem. So far it is working!!!!
    Right mouse click on One Drive and click on sync.
    All docs are now opening and saving fine and no sign of read only.
    One drive should sync automatically.... but for now until they come up with a fix, we probably will have to do it manually.
    2014-11-05T04:33:57+00:00
    None of these fixes have helped me unfortunately.  It is literally driving me insane!  Has been four weeks so far!
    If I right click on the Onedrive folder and go to Properties, "read only" is always checked.  I uncheck the "read only".  Also then do the same for the folders that I want to open within my Onedrive i.e. uncheck the read only.... and my documents are opening as read only!!  Then if I go back to see if the Onedrive folder has reset itself to read only.... yes it has.
    I have uninstalled Onedrive several times now trying to fix this issue but no joy
    When I am within Word on my desktop and open a file within my Onedrive folder, shouldn't that file open from my computer memory instead of "downloading from onedrive"???
    Any other suggestions would be greatly appreciated.
    2014-11-26T12:11:47+00:00
    I found that I was having this read-only problem with only one file recently and came across this thread in my search. The things suggested here didn't appear to be the answer but it gave me the idea to compare the properties to other files that were working. This one file did not give any permissions to my OneDrive (Microsoft account) user.
    From File Explorer:
    Right click the file
    Select Properties
    Go to the Security Tab
    Click Edit...
    Click Add...
    Type in your Microsoft account login ID
    Click OK (on all 3 windows)
    I've checked out nearly every other file in that folder and the one file I had issues with was the only one missing the Microsoft account.
    I only did this just now, so I'm not sure if this is a long-term fix but I've since updated the file, saved it, closed it and re-opened it and it came up with full permissions.
    I'm definitely interested to know if this helps solve the problem for anyone else.
    2015-02-06T15:52:19+00:00
    Adding OneDrive as trusted location makes no  difference.
    2015-02-06T16:16:54+00:00
    This cured the read-only issue for me when opening files in Office 2013
    Open File Explorer
    Right Click on the OneDrive
    Select Properties
    General Tab
    Attributes: if there is a little black square in the Read Only Box - click on it to remove
    Select Apply
    Select OK
    You will get a confirmation dialog that asks if you want to apply to all files & subfolders
    Select OK
    Another dialog will appear showing progress of updating file attributes
    It will go away when complete
    You Should have no more read only issues
