Need help with conditional formatting using an IF function to recognise blank cells and overdue dates
2013-07-04T01:44:42+00:00
Hi
I am wanting to add conditional formatting to a spreadsheet which lists invoices and their due dates, along with payment date.
One column (H) has the payment due date.
Another column (M) has the date paid. This column is left blank if unpaid to date.
I want to highlight only cells in column H in which the due date is anything less than today, but ignoring those where there is a value in column M already. Essentially, I do not want to highlight anything which is overdue, but already paid (if that makes sense).
Having trouble working out what formula I need to do to show this in the conditional formatting area. I can get it to do the dates past easy enough, but cant get it to also ignore blank cells.
Have tried using ISBLANK.
Would greatly appreciate anyone's help with this formula!!
Thanks!!
Ashish Mathur 102.4K Reputation points Volunteer Moderator
2013-07-04T02:40:07+00:00
Try this
  1. Click on cell H2 and go to Home > Conditional formatting > New Rule > Use a formula to determine which cells to format
  2. In the formula bar there, enter this formula
=AND(H2<today(),I2="")
  1. Click on Format and select any Fill/Font colour
  2. Click on OK/Apply
  3. Copy cell H2, select H3:H50 right click > Paste Special > Formats
Hope this helps.
59 additional answers
  1. Ashish Mathur 102.4K Reputation points Volunteer Moderator
    2014-04-10T01:07:04+00:00
    Let's start with a clean slate.
    1. Select I14:I1251 on the "P.I Master CAR" worksheet and go to Home > Conditional formatting > Clear Rules > Clear Rules from selected cells
    2. Select I14:I1251 on the "P.I Master CAR" worksheet and go to Data > Data Validation > Allow > Any value.  Delete all entries in range I14:I1251
    3. In cell I14, enter this formula and copy down
    =IF(J14<>"","Completed",IF(AND(TODAY()>H14,H14<>""),"Overdue",IF(H14<>"","On Target","")))
    Now enter various date in columns H and J to check for whether the text in column I is OK or not.
    Once you are OK with the text that appears in column I, we will take up the next task of conditional formatting.
    2014-04-10T05:09:23+00:00
    Works well.
  3. Ashish Mathur 102.4K Reputation points Volunteer Moderator
    2014-04-10T05:15:23+00:00
    If this is OK, can you now figure out the conditional formatting yourself?
    2014-04-10T05:52:26+00:00
    Hi Ashish,
    Thanks for all your help. I just need help with two more things.
    • I have updated the document but I notice that the last completed cell will always stay clear unless the cell under it has data in it.
    • Also, I could not figure out how to create conditional formatting for 'On Target' to be BLUE.
