Need help with conditional formatting using an IF function to recognise blank cells and overdue dates
2013-07-04T01:44:42+00:00
Hi
I am wanting to add conditional formatting to a spreadsheet which lists invoices and their due dates, along with payment date.
One column (H) has the payment due date.
Another column (M) has the date paid. This column is left blank if unpaid to date.
I want to highlight only cells in column H in which the due date is anything less than today, but ignoring those where there is a value in column M already. Essentially, I do not want to highlight anything which is overdue, but already paid (if that makes sense).
Having trouble working out what formula I need to do to show this in the conditional formatting area. I can get it to do the dates past easy enough, but cant get it to also ignore blank cells.
Have tried using ISBLANK.
Would greatly appreciate anyone's help with this formula!!
Thanks!!
Ashish Mathur 102.4K Reputation points Volunteer Moderator
2013-07-04T02:40:07+00:00
Try this
  1. Click on cell H2 and go to Home > Conditional formatting > New Rule > Use a formula to determine which cells to format
  2. In the formula bar there, enter this formula
=AND(H2<today(),I2="")
  1. Click on Format and select any Fill/Font colour
  2. Click on OK/Apply
  3. Copy cell H2, select H3:H50 right click > Paste Special > Formats
Hope this helps.
59 additional answers
    2013-07-04T03:00:48+00:00
    Thankyou so much! Works perfectly!
  2. Ashish Mathur 102.4K Reputation points Volunteer Moderator
    2013-07-04T03:17:10+00:00
    You are welcome.  If my reply helped, please mark it as Answer.
    2013-07-04T03:21:20+00:00
    Done!
    Cheers :)
    2014-02-26T17:34:27+00:00
    Hello
    Need assistance!
    For my conditional formatting on an excel spreadshhet, I have Date Issue Received in column F and Date Issue Resolved in column G. If the issue is not yet resolved, column G will be blank. I need to highlight cells in column F where column G is blank or the date entered into column G is 8 days or over from the date entered in column F.
    What formula do I use?
    Many thanks!
