No matter how good of a picture I have when I insert it into Visio 2013 Pro, it is blurry.
2013-09-04T19:04:00+00:00
I get blue prints as JPG PNG BMP but no matter how good the quality of the picture, after it is inserted into Visio none of the words can be read.  I even used a 600 dpi 36"X24" crystal clean blueprint and it still looked blurry or pixilated in Visio.  What's the deal with this $300 software?  I can open up the bmp png jpg in previewer and it looks great zoomed in by the way.
Microsoft 365 and Office | Access | For home | Windows
    2013-09-09T09:49:10+00:00
    Did you solve the issue?
    If the issue exists, we may also check the picture format.
    Please check the following picture:
    Regards,
    George.zhao
    2013-09-05T03:09:17+00:00
    Thanks to your feedback.
    Did you print a Visio drawing or insert a picture link people photo?
    Did your print machine print other programs’ picture such as Word, Excel cleanly?
    I test in my computer.(Test PNG 352935 pixels)
    I inserted test.png to Visio2013. Please refer to the following picture:
    Did you use “Picture” command to insert and put Zoom 100%?
    Then I recommend we can check the print setting. Please refer to the following pictures:
    I hope it’s helps.
    Regards,
    George.zhao
