Excel is not working Error "We're sorry, but Excel has run into an error that is preventing it from working correctly".
2013-07-03T09:59:22+00:00
I have installed O365 all apps are working fine except Excel it is giving Error "We're sorry, but Excel has run into an error that is preventing it from working correctly". Excel will need to be closed as a result.it is giving repair option however tired both repair option online and offline issue is still unresolved.
2013-07-04T05:24:23+00:00
Hi
As per the description you are facing issue while trying to access the Excel program. Let me assist you with the issue.
Does the error pop up as soon as you click on the Excel program to open or once the Excel is opened?
Try the steps below and check if it helps:
Step 1:
Try to open Excel in safe mode and check if it opens:
· Hold Windows key + R.
· Copy and paste, or type the following command in the Open box, and then press Enter:
Excel /safe
Note: There is space between Excel and**/**
If the issue does not occur in Excel safe, then try to disable add-ins associated with Excel 2013 and check the result.
· Click on File menu, Options and then Add-ins.
· Click on Go button besides Manage: Com-in Add.
· Check if there are add-ins listed, clear the checkbox to disable them.
Step 2:
If the above step fails, try the step below:
Right click on Excel (.exe) > Properties > Compatibility > uncheck all the boxes, click Ok and check if it helps.
To access Excel (.exe), open the following location:
C:\Program Files\Microsoft Office\Office15\Excel.exe
Or
C:\Program Files\Microsoft Office 15\Root\Office15\Excel.exe
Try to open Excel and check if it opens.
I hope the above steps helps. If you need further assistance on this particular issue or any other Office related issues let us know and we will be glad to assist you.
Thank you.
55 additional answers
    2018-07-25T17:22:49+00:00
    I tried all the steps listed above except for the File-Options-Add-ins.  When I go to the File tab there is no "Options" option.  How do I fix my Excel program?  I need to work!!
    2018-08-08T01:08:08+00:00
    I have tried all of what was suggested.  Nothing helped and I am still getting the same error.  Please help!
    Thank you
    Stacie
    2018-08-09T08:33:50+00:00
    Thank you
    Stacie
    Nothing worked for me either.
    Ended up having to reinstall Office 365.
    Cheers
    John
