How to display figure number only in cross reference
2012-03-09T17:01:27+00:00
Is there a way to have a cross reference to a figure only display the number, without displaying the label?
For example, I want to reference several figures at once, so it is most natural to say "see Figures 1,3,6, and 9".  It is less natural to say "see Figure 1, Figure 3, Figure 6, and Figure 9",
Stefan Blom 352.7K Reputation points MVP Volunteer Moderator
2012-03-09T19:53:23+00:00
After you have inserted the cross-reference, add a so-called numeric picture switch to specify a number format. To do that, press Alt+F9 to display field codes; you'll find that the cross-references are REF fields. Add # "0" to the end of the relevant REF fields. Press Alt+F9 again to hide the codes, and press F9 to update fields in the selection.
Alternatively, manually add a bookmark around the figure number and then insert a cross-reference to the bookmark text.
2012-03-15T22:46:33+00:00
OK, if heading numbering is included with the captions, you can't use the workaround with the numeric switch.
Edit: You actually can use a numeric switch; see Suzanne's article at http://wordfaqs.mvps.org/CombineXrefs.htm.
As previously suggested, you can add a bookmark around the caption number and insert a cross-reference to bookmark text. Alternatively, use the "kludgy" workaround in the article at http://wordfaqs.mvps.org/CombineXrefs.htm.
55 additional answers
  1. Stefan Blom 352.7K Reputation points MVP Volunteer Moderator
    2016-03-24T00:17:45+00:00
    Fortunately, there is a simple way to create cross-references to captions: just add a bookmark manually, making sure it encloses the particular range that you want to reference, and then insert a cross-reference to bookmark text. (I mentioned this in a previous post as well.)
    2016-03-24T16:59:07+00:00
    I'll probably use that from now on, even though it's a bit tedious when you have large numbers of figures and tables.
    Another advantage is you can switch between numbering schemes without having to edit every cross-reference field.
    2016-10-25T17:10:06+00:00
    I just tried this with success in Word 2010.
    Under "Cross-reference", select "Only label and number". Insert the first reference, for example Figure 2. After the digit 2, type a dash or whatever separator you want. Then insert the second figure (label and number), for example Figure 5. Then position the cursor just to the left of the "5" and hit the delete key enough times to delete the word "Figure" and its trailing space from the second reference. If you delete just to the right of the dash, you'll see just the bare "5" with its own highlighted reference blue box.
    When it updates, it adds the "figure" back in
