How to display figure number only in cross reference
2012-03-09T17:01:27+00:00
Is there a way to have a cross reference to a figure only display the number, without displaying the label?
For example, I want to reference several figures at once, so it is most natural to say "see Figures 1,3,6, and 9".  It is less natural to say "see Figure 1, Figure 3, Figure 6, and Figure 9",
Stefan Blom 352.7K Reputation points MVP Volunteer Moderator
2012-03-09T19:53:23+00:00
After you have inserted the cross-reference, add a so-called numeric picture switch to specify a number format. To do that, press Alt+F9 to display field codes; you'll find that the cross-references are REF fields. Add # "0" to the end of the relevant REF fields. Press Alt+F9 again to hide the codes, and press F9 to update fields in the selection.
Alternatively, manually add a bookmark around the figure number and then insert a cross-reference to the bookmark text.
2012-03-15T22:46:33+00:00
OK, if heading numbering is included with the captions, you can't use the workaround with the numeric switch.
Edit: You actually can use a numeric switch; see Suzanne's article at http://wordfaqs.mvps.org/CombineXrefs.htm.
As previously suggested, you can add a bookmark around the caption number and insert a cross-reference to bookmark text. Alternatively, use the "kludgy" workaround in the article at http://wordfaqs.mvps.org/CombineXrefs.htm.
55 additional answers
    2015-05-19T00:52:00+00:00
    Good improvement Stefan. Much more elegant.
    Where would we be trying to solve Word problems WITHOUT knowing how to work with Excel...
    2015-05-20T10:01:07+00:00
    Thanks a lot! Adding # "0;0;0" did the trick.
  3. Stefan Blom 352.7K Reputation points MVP Volunteer Moderator
    2015-05-20T14:00:13+00:00
    You are welcome!
