Problem with copy & paste in Excel 2010
2012-03-16T10:47:34+00:00
I am running Excel 2010 on Windows 7. I am having a problem with the cut and paste command. This has worked OK for the few months I have been using the program, but the paste options have suddenly stopped working properly.  When I click on paste special, the only options shown are unicode text or text, with no explanation. When I copy and paste formulas, e. g. autosum,  it is not applying them properly to the selected cells, or it is just pasting the values of the copied cells. I have tried uninstalling and reinstalling Office Home and Business 2010, but the problem is still there. Any ideas?
HansV 462.7K Reputation points MVP Volunteer Moderator
2012-04-11T19:23:19+00:00
Skype has released an updated version of the Click to Call browser add-on that should be free of the problem mentioned above.
If you want it, go to http://www.skype.com/intl/en-us/get-skype/on-your-computer/click-to-call/windows/ and click Download Now.
Moderator Note
For more information on this issue, please see the following sticky:
Text loses formatting when I use Cut, Copy, Paste, Paste Special or Format Painter in Excel
60 additional answers
    2012-03-27T22:36:54+00:00
    You're the man!  I uninstalled Skype Click to Call and Excel works perfectly now.  (I don't use Word much so don't know if I had a problem there.)  Interesting thing when I went to uninstall Skype Click to Call, I also had a separate Skype 5.5 program.  I left this program on my computer, only eliminated Bad Skype.  5.5 doesn't interfere with Excel so you can still use Skype.
    2012-03-27T22:39:33+00:00
    I am using:
    • Windows 7 32-bit Ultimate
    • Office 2010 Professional
    • Firefox 11.0
    • Skype 5.8.0.158 with Skype Click to Call
    When I copied, the usual dancing ants are missing and I was unable to paste formatting.
    After I disabled Skype Click to Call, the problem disappeared.
    I hope this helps others.
    2012-03-29T20:37:44+00:00
    I also uninstalled Skype Click to Call and it seems to have resolved the issue.
    Thanks for the help !!
    2012-03-29T23:29:22+00:00
    OMG! This was driving me nuts!! Thank you so much!!!
