Problem with copy & paste in Excel 2010
2012-03-16T10:47:34+00:00
I am running Excel 2010 on Windows 7. I am having a problem with the cut and paste command. This has worked OK for the few months I have been using the program, but the paste options have suddenly stopped working properly.  When I click on paste special, the only options shown are unicode text or text, with no explanation. When I copy and paste formulas, e. g. autosum,  it is not applying them properly to the selected cells, or it is just pasting the values of the copied cells. I have tried uninstalling and reinstalling Office Home and Business 2010, but the problem is still there. Any ideas?
HansV 462.7K Reputation points MVP Volunteer Moderator
2012-04-11T19:23:19+00:00
Skype has released an updated version of the Click to Call browser add-on that should be free of the problem mentioned above.
If you want it, go to http://www.skype.com/intl/en-us/get-skype/on-your-computer/click-to-call/windows/ and click Download Now.
Moderator Note
For more information on this issue, please see the following sticky:
Text loses formatting when I use Cut, Copy, Paste, Paste Special or Format Painter in Excel
60 additional answers
    2012-06-21T16:52:22+00:00
    This fixed it for me! Thank you ever so much, I thought I was going mad :-)
    I'm using Office 2007 SP3 by the way.
    2012-07-02T13:03:57+00:00
    Thanks for your suggestion. It perfectly work for me. PDF complete is the addins which create problems for me.
    Thanks once again.
    Regards,
    Suvendu Sarkar
    Kolkata, WB, India
    2012-07-05T20:09:24+00:00
    Guruprasad Ra,  Can you carry this info back to the engineers?  These users have provided a pretty good description of the problem and the software involved and seem to have been able to point to the updates of March 14 as a possible causative factor in it all.
    Based on other discussions, this is affecting cut-n-paste and copy format (with the format painter) at the very least.
    I came across the copy and paste problem today in excel 2010 and followed  the above prescribed solutions of which none worked for me. I eventually resolved it at the end of the day by clicking the 'calculate now' icon in the formulas toolbar.
    2012-07-09T07:45:22+00:00
    I have had the same problem with office 2010 professional and windows 7 64 bit etc.  Unable to cut and paste formulas or formats, etc absolutely maddening.  Tried repair, re-installing all to no avail.  I use chrome as my browser and sometimes explorer.
    Just un-installed Skype 'click to call' add on and hey presto it all works again.  Thanks for the answer and thanks Skype for a massive headache!
