Proofing tools for Office 2010
2013-04-07T12:54:21+00:00
I'm trying to find proofing tools for Office 2010 on MS site, but something is completely wrong. All the links now bring me to the Office 2013 options. Even the link "Download a Language Pack for Office 2010" on http://office.microsoft.com/en-us/language-packs/office-2013-language-options-FX102851176.aspx brings me to Office Language Pack 2013 page.
Actually I don't need the full language pack, I just need the spellchecker working for some languages (russian, estonian, some more). As I see it is possible to freely download such proofing tools for Office 2013, but they don't work with Office 2010.
What I show do and where I can them?
Thanks in advance,
Vadim
    2016-01-06T10:49:23+00:00
    Thanks Doug, but to say that's disappointing would be a massive understatement. Given these were free with my win 7 ultimate install and office 2010, for Microsoft to expect me to now pay for an upgrade and then pay for the language packs just ain't gonna happen any time soon. I guess I'll go use some different tools.
  2. Doug Robbins - MVP - Office Apps and Services 323.6K Reputation points MVP Volunteer Moderator
    2016-01-06T12:54:48+00:00
    While you had to pay for Language Packs for Office 2010, they are, for the most part, free for Office 2016
    2016-09-01T20:03:24+00:00
    I need spanish proofing tool on Office 2016. The language is there but the proofing tool not. Strange enough the language pack is correctly installed, even if I cannot unistall it from Windows control panel. Any suggestion? Thanks
  4. Stefan Blom 352.1K Reputation points MVP Volunteer Moderator
    2016-09-01T22:03:33+00:00
    Make sure that you installed the correct version. You'll need the 32 bit version ("x86") of the language pack for 32 bit Office. Most Office installations are 32 bit, even on 64 bit Windows, and this is actually the configuration that Microsoft recommends for most users.
    2016-09-02T18:39:24+00:00
    Thanks Stefan. That was exaclty the proble. I had to go trhu 3 deinstall/install before to find out... :(
    At least it is solved. Thanks a lot!
    ciao
