As I wrote, this is a display issue only; the same applies to settings in many other dialog boxes, as Suzanne mentions in her reply. Formatting is working as designed.
Thank you both for the speedy replies! I understand what you've said about what you're describing being a display issue only. I think I must be having a different problem, then.
My most common need for making proofing changes is to prevent spell-checking of dozens of lines of program code (SQL) that I've pasted either into Word documents or into Outlook e-mails (with Word as the e-mail editor).
So here are my exact actions; I'm using 32-bit Office 2010 on 64-bit Windows 7 Professional:
- paste in the plain text (which causes Word to flag many of the keywords as spelling errors)
- select all the pasted text as a single block of lines (usually leaving some other text unselected, before and after)
- go to Set Proofing Language
- observe that the "Do not check spelling or grammar" checkbox is in the indeterminate state (neither checked nor unchecked)
- click the "Do not check spelling or grammar" box so that it is now definitely checked
- leave the "Detect language automatically" option checked
- hit the OK button
And here's the rub: if I've selected "too much" text, nothing appears to happen--the spelling errors in the selection are still flagged. And If I go right back into the Set Proofing Language dialog for the same selection, the "Do not check spelling or grammar"
option is still in the indeterminate state, neither checked nor unchecked. So that's why I said it appears that the change didn't "stick".
If I select fewer lines at a time and repeat the same actions on each smaller grouping, then I observe that for each one, the "Do not check spelling of grammar" checkbox is initially unchecked (not indeterminate), and when I check it and hit OK, the
spelling errors are no longer flagged, and then again going back in to the dialog confirms that the option is still clearly checked for that grouping.
If I were pasting this text from another Word document or some other formatted source, I'd suspect that the clipboard text might be pre-formatted with a mix of language options upon pasting into the new document, which might explain the initial indeterminate
state of the "Do not check spelling" checkbox and I suppose could interferre with Word's ability to apply a change to the whole selection (though even then I don't see why). But in fact I'm pasting in plain, unformatted text.
In short, the appearance is that it's somehow the size of the selection that determines whether the change can be made to the whole selection at once. I'd like to understand this and find a way to avoid having to break up the text into smaller selections (guessing
each time as to how small to go).
I hope you have more thoughts on this!
