"do not check spelling or grammar" will not stay unchecked
2013-04-28T04:05:48+00:00
Hi - I have a document that's been merged from a lot of single documents. When I run spellcheck, I always get the "Text marked do not check has been ignored." So I go to Review, Language, Set Proofing Language, and there is no language set and the box "Do not check spelling or grammar" has the half on/half off box in a box. When I click it twice, it clears, and I set the language to English, but when I go to re-check for spelling, I get an immediate "The spell check is complete", and when I go back to review, language, set proofing language, the check box is back to the half on half off setting and no language set. I am doing select all text each time, too.
Office Professional Plus, version 14.0.6129.5000 64-bit
Suzanne S Barnhill 279.4K Reputation points MVP Volunteer Moderator
2013-05-06T18:34:51+00:00
Finding elusive "no proofing" text can be frustrating. When you select the entire document, you are selecting only the text layer. This doesn't include headers and footers and may not even include footnotes and endnotes. In one instance, I found "no proofing" text in an unused header. Here's how to ferret it out.
  1. Press Ctrl+H to open the Replace dialog and then select the Find tab (to my mind this is the easiest way to get to the Advanced Find without bothering with the Navigation pane).
  2. Click More>> to expand the dialog.
  3. Leaving the "Find what" box empty, click Format, then Language.
  4. Check the box for "Do not check spelling or grammar" and click OK. You'll see "Format: Do not check spelling or grammar" beneath the "Find what" box.
  5. Since "Find in" allows you to search only one layer at a time, it will probably be quicker to use "Find Next" (the likelihood is that there will be only one hit, anyway).
  6. Note where the found text is located. In the instance I cite, it was in an Even Page Header. Although "Odd and Even" was not currently enabled for headers and footers, Word had remembered the text entered for the Even Page Header, and it was formatted as "Do not check spelling or grammar." I could never have found this merely by inspecting the document in its current state.
Stefan Blom 353.5K Reputation points MVP Volunteer Moderator
2013-04-28T16:27:16+00:00
Depending on the size of the selection, check boxes may appear greyed out; this is by design in Word...
Or you saying that the message "Text marked with 'Do not check spelling or grammar' was skipped" also resurfaces? Have you looked at the style definitions involved? For example, see if "Do not check spelling or grammar" has been added to the Normal style.
46 additional answers
    2013-05-06T18:13:53+00:00
    The selection is my dissertation, 300 pages, because I don't know how to find what might have been marked "don't check".
    Yes, after running spell check again, the "text marked ..." message still appears. Every time I go in and clear the check box, it's not greyed out, it's got the half-filled symbol that means it applies to some of the text but not all. I click this twice, so it goes to fully checked and then fully cleared, but as soon as I go back to the document and back in to the language preferences, it's back. by checking some of the pages as groups, I've found that at least part of the problem is tables.
    However, it's still frustrating that I'm allowed to "clear" the checkbox but it immediately gets overridden by something else. I would expect the option to be completely greyed out if it was not possible to change the entire document this way.
    2013-11-25T17:11:45+00:00
    Stefan, I have been searching a long time and your post is the first I've ever seen that mentions "Depending on the size of the selection, check boxes may appear greyed out; this is by design in Word".
    Typically posters (and Microsoft itself) just say to select your desired text, or use Ctrl-A to select the whole document, and then apply proofing changes to the selection; but they don't ever mention that there is a limit to how much text may be selected for the proofing change to "stick".
    Can you tell me what the selection size limitation (the actual size value) is, please?  If you could also comment on where this is documented, and why the proofing change is accepted without warning if too much text is selected, I'd be very interested in hearing about that as well.
    Thanks!
    P.S.  Suzanne S. Barnhill, your answer was helpful as well.
  3. Suzanne S Barnhill 279.4K Reputation points MVP Volunteer Moderator
    2013-11-25T18:57:47+00:00
    No, if you Select All and clear the check box, the setting will "stick." It just may not be accurately represented in the dialog when you select the entire document. This is true of most settings in Word. If you select a large number of paragraphs, all formatted identically, and go to the Paragraph dialog, you may see the Spacing Before/After settings and others blank even though all the paragraphs are formatted the same. But it's more common to see shaded boxes when the formatting is mixed.
